Outlook sync problem
davpel
Jun 22, 2007
I have tried and tried in vain to get the iPhone to sync with Outlook 2007. iTunes indicates that it is doing a sync, but when it is completed, there are no contacts or calendar data on the device. Anyone else have this problem/discovered a solution?
T-HAN
May 11, 2007
85
I have the 2000 version :( But I am having the same problem with my contacts... I cant call anyone cause I don't have my contacts!:mad:
HELP!
topshotta
May 21, 2007
27
I had the same problem - can't synch at all with Outlook 2003. I ended up putting all my contact info in Yahoo and sycnhed that way. Sucks though because I have my calendar in Outlook etc.
T-HAN
May 11, 2007
85
Please explain this process...
pharoh
Jun 28, 2007
35
Why would you buy an Apple product and expect it to work smoothely with a Windows PC? Its like buying Mercedes parts and trying to install them in a Volkswagen.....One day everyone will own a Mac...
T-HAN
May 11, 2007
85
...so helpful...
rj5620
Jun 2, 2007
70
I can't get any sound out of this phone w/o headphones, but the sync was fine in Vista and Outlook 2007, contacts, cal etc. I put songs and photos and that went well too. Still can not use phone as a phone though and I got an email stating that it is activated. I did not get the sms message. Very frustrating.
topshotta
May 21, 2007
27
Sign up for a yahoo account and once there input all of your outlook contacts into Yahoo contacts. When synching the iPhone choose Yahoo as the contact source. You will be prompted for your yahoo id and password.
lasquintanas
May 21, 2007
199
Outlook '07 works fine here. Did you tell iTunes thats the program you wanted to sync from? That's all i did.
jstemp33
Jun 20, 2007
27
i am getting a message of Load 25 more messages when viewing my inbox!
Any thoughts?
rj5620
Jun 2, 2007
70
Took the iFlop back and got an iPhone!
Got a different phone and totally different animal.:cool:
wineexec
Fixed Outlook syncing problem
I too was having this issue and Apple support very friendly but no help. As usual with Outlook, whenever I setup new e-mail accounts or add any new hardware, I always seem to have to restart my machine to get it to work. So I did 3 things:
1) Unplugged the device and USB plug
2) Powered down the iPhone and also did a reset on the iPhone
3) Restared my computer
One my PC restarted I reconnected the iPhone. Then it will ask if you want to restore from backup and I said "yes". At that point it started syncing everything and wha-la, it is there! At least contacts and calendar. Now off to figure out my mail issues...:laugh2:
T-HAN
May 11, 2007
85
Still no bookmarks... Any help?
c1ockwerk
39
outlook 2003 crashed for me 5 straight times says problems with apply outlook sync or soemthing
drconehead2000
Jul 2, 2007
98
My solution for Outlook 2003 Sync
So I was unable to get my contacts or calendar to sync with outlook 2003 so there were 2 things that needed to be done.
1.) Within outlook, click help>check for updates
After you ensure you have the latest updates, try and and sync again. If this doesn't work, go to step 2.
2.) Within outlook, click help>detect and repair
**Note, make sure you have backed up all your contacts and calendar.
Once this is complete, I got the sync to work no problem!
Hope this helps!
jjc
Jul 3, 2007
Hope this helps!
Well it didn't do it for me. I have done everything and it doesn't sync with Outlook 2003. Any other ideas?:(
drconehead2000
Jul 2, 2007
98
Nope, sorry...I managed to get mine working using the scheme I suggested, and it worked on two different computers....sorry....
i-Fred
Jul 3, 2007
San Carlos, CA
Outlook 2002 sync bug
I am able to sync with Outlook 2002 with onlyone problem-- it doesn't sync any of my recurring events that were created on the pc. I tried recreating them from scratch, and setting an end date but no luck. Anybody else having this issue?
gcarver2
Jul 4, 2007
Outlook 2003 Sync Fix
At last! Go to Outook. On menu, go to Tools/Options. Pick the Other tab, then Advanced Options. Look for COM Add-Ins and select the two iTunes choices.
Voila!
jjc
Jul 3, 2007
Voila!
You are the man!:laugh2: It worked perfect. After many hours with the iPhone people and Outlook people you saved the day. Someone needs to tell Apple. They are desperately trying to solve this problem. ;) Thank you!
