Outlook sync question
beej
Jul 31, 2007
131
When I first purchased my iPhone, I entered all my contacts manually (I don't have that many). I was under the impression that iTunes would make a backup of my contacts when I synced.
Now that I've learned that I was mistaken, I'd like to use outlook (which I don't currently use) to backup my contacts. Will iTunes sync outlook with the iPhone contact list, or am I stuck entering everything into outlook manually?
sruize
11
When I plugged my iPhone in it synced with iTunes it synced with outlook and all my contacts was backed up
beej
Jul 31, 2007
131
So when I sync with iTunes it will move my contacts FROM my iPhone TO outlook?
sruize
11
It did for me cause i had to restore my iPhone and all my contacts went straight back so just check the outlook box and it will sync your contacts every time you sync you iPhone
cdp1276
Aug 3, 2007
Fairport, NY
I'm having the same problem that Contacts sync from Outlook to iPhone but if I add or change in the iPhone they aren't sync'ing back to Outlook. Any ideas?
I have the latest iTunes 7.3.2.6 and iPhone 1.0.1.
sruize
11
well I added about 100 numbers to my phone book yesterday and I synced with my pc and it went into my outlook
