Outlooksyncclient.dll disappeared
Oct 10, 2007
I'm an HP notebook user with Windows XP sp2.
I got my iPhone back when they were first released, and after initial problems syncing I was able to fix it by enabling the COM add-ins "iTunes outlook addin" and "outlook sync client" add-in. However, after installing the latest update of iTunes the file outlooksyncclient.dll has disappeared from my computer.
After reading information about where it was located I would go to the file and it is not there. I have the files "outlooksyncclienthelper.dll" and "outlooksyncclient.exe" but no "outlooksyncclient.dll".
This has only caused minor problems in syncing (such as adding appointments onto my outlook calendar from my phone when I had previously deleted them from the outlook calendar), but I am curious to see if anyone else has had this problem, and if so how to get the dll file back?
mouron13
Jan 13, 2008
Vevey - Switzerland
outlooksyncclient
Hello, I just read your mail and I will know if you find a solution to the problem. I bought an Ipod touch, I was sincing very well for 2 weeks and now since to weeks ago when I sync the Calendar, the outlooksyncclient message appears. I can sink from the pc to the Ipod but not the contrary. I really need help to find an issue to this problem. Can you help me?
Thanks for your answer.
Michel from Switzerland:(
mouron13
Jan 13, 2008
Vevey - Switzerland
OutlookSyncClient
Kimo, your help is really helpful but there is still a problem. Under Vista I don't find the documents and settings folder, even when I select to see the hidden folders. No DOCUMENTS AND SETTINGS and for this reason I don't know where I can foud my outlook.pst.
Can anybody give me one more chance to solve the OutlookSyncClient message?
Thanks!;)
