Output to car stereo. Works with iPod but not iPhone
SingleDouble
Jul 13, 2007
40
I have a 2007 Mazda which has a simple input to the car stereo which works simply and brilliantly with the ipod.
Same cable, same hookup, but it doesn't work with the iPhone. (ugh!).
Anyone know why or have the same experience?
Thanks!
xoulo
Jul 9, 2007
323
not for the mazda, but i have the one that runs trhought the radio signal. you know what im talkiing about?
but yeah. that one doesn't work, it can still charge but cnat play through stereo
SingleDouble
Jul 13, 2007
40
Someone else must have posted about this issue. I mean, it's a biggie (well for me anyway ;)
I mean if I have to carry one more device, I'm gonna kill :)
tharmsen
Jul 5, 2007
873
For some reason Apple elected to do something differently with the connector pins on the iPhone. You would have thought that they would have left it the same as the 5G iPod video... so we wouldn't need new adapters to do things like listen to music over our stereos or even use existing docks. My DLO FM transmitter doesn't work with my iPhone either...
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
My car audio (factory) comes cd/cassette, and the cassette adapter for mp3 players works fine with the iPhone. Are you ppl talking about a direct connection, or a connection through an adapter?
Domin8stang
Jun 25, 2007
90
I have an alpine CDA-9856 with iPod integration and i can use my iPhone and control it through the headunit. When i get a call, the music fades and the ringtone plays just like with the headphones on...i can even answer a call while its plugged in and use it like a normal phone, then hang up and the music goes back through the speakers...I have yet to try speakerphone though and see if that will feed it through the speakers or not.
direktor
Jun 26, 2007
i have a JVC KD-AVX2 head unit in my car that came with a JVC KSPD100 Ipod Adapter that you plug into the Dock Connector and it works just fine...just cant pick up the phone when i get calls while its plugged it or the speakers make that funny noise
You need the bluetooth adapter, homie.
My AVX33 works awesome with the iPhone.
amr005
Oct 2, 2007
I am having an issue with my ipod interface kspd100...i cant get it to work with my iPhone and kdavx33. Did you have to do anything special to make this work? I also called JVC and they said that it wasn't compatible with the iPhone and your saying it is. maybe you could shed some light for me on this issue...thanks
pooh
Sep 3, 2007
20
Baton Rouge, La.
<P>ima car stereo installer and for the record the iPhone does work with 90%<IMG alt=0 src="http://forums.everythingicafe.com/images/smilies/laugh4.gif" border=0 smilieid="27"> of the radios i have tested mine on(sony pioneer eclipse alpine)... and when i say it works i mean through the direct ipod adapter and&nbsp;to confirm what Hondamaker says it does fade the music and &nbsp;rings through the speakers but u cant talk through it like a bluetooth adapter<IMG alt=0 src="http://forums.everythingicafe.com/images/smilies/embarrassed2.gif" border=0 smilieid="21">....&nbsp;</P>
GoldstarQC
Oct 9, 2007
Hi, I have a KS-PD100 too and a JVC KD-BT1 Head Unit. I can get my iPhone to work as a bluetooth phone. When I connect the KS-PD100, iPhone display the message about the Airplane mode. Yes or No do the same for me. The head unit display 'File Check' and that's it. The iPhone display Accesory connected.
Is there anything I can do to make it work ?
Thank you... Hope it will work !
GoldstarQC
RedbullRR
Dec 26, 2007
I use the Tape Deck Adapter. Cut off a lil plastic on the end that goes into the iPhone so no need to get a TTY adapter.
msschwarz
May 13, 2008
My iPhone also does not work in the car.
Thanks!
I have been to the Apple store 2x and explained my issues since my current port in the car does not allow the music to play through the speakers on my iPhone. I purchased a new cable the Apple store recommended and it didn't work. I returned it and purchased the specific jack to attach to original cable I have and it still doesn't work. I even had my iPhone tested at the Apple store to make sure it wasn't a problem in the phone and we attached a headset to the port on the phone and it worked fine. I am so frustrated. P.S. the Ipods my family has work just fine in the car! Any other suggestions?
