Overheating iPhone
Dipsxxy
Aug 1, 2010
174
74
Doe anyone have any problems with their phone getting hot? I notice my phone gets hot every time I charge it.
Dipsxxy
Aug 1, 2010
174
74
I was having the same problem sporadically. Realized it was my griffin charger (both wall and car) only use the USB now and it's stopped
I'm wondering if it's my charger. The charger even gets hot. I have my phone since last October and this just started happening recently
katelynneemma
Jan 15, 2011
683
98
30
N.Y.
I would deffinatly try a new charger. I do believe that If you take it to an Apple store (assuming it's an Apple USB cord) and tell them the problem they will replace it.
Watcher
Mar 29, 2009
1,785
30
Phoenix, AZ
I have only used a Griffin charger since 2008 and I have never had the iPhone get hot on me. I often charge it overnight with it being very cool to the touch in the morning. I personally think Griffin makes one of the best aftermarket charging cables and USB car chargers around.
Watcher
Mar 29, 2009
1,785
30
Phoenix, AZ
Do anyone have any
Problems with their phone getting hot? I notice my phone gets hot everytime I charge it.
Have you ever received the temperature warning while charging the iPhone as shown in the screenshot below? If so, you need to take your iPhone to an Apple Genius ASAP.
offroadhunter
Apr 1, 2009
682
22
New York
I run nav, charge, and talk on the phone at same time in the car and it get's real warm... I brought it to Apple genius bar a while back and they claimed its normal for the iPhone to run hot under those circumstances and nothing to worry about, never had any physical problems with the phone (nor has it caught fire) so I guess he wasn't totally wrong.
mayflower
Apr 20, 2011
22
maybe most phones have this phenomenon. if it is just a little hot, it is common. To avoid this problem:
Do not use your phone while charging, and you'd better keep your phone power on while charging.
Kylezert
Dec 7, 2011
17
Orange, California
To dipsxxy and Bennyboy I know about electricity and I can tell you from experience that you iPhone/wall chargers are not made designed to used while charging that is why they will over heat. Now the car charger is a whole different story since the power is coming from a battery known as "DC" or direct current your charger does not have to convert it and the charger won't heat up. The reason why your wall chargers heat up is in a house it is running on "AC" or alternating current so it has to convert the AC power to DC causing heat. To sum up you can use the phone while charging in the car but it is not recommended that use use it for very long if you can prevent it when charging in the house.
Eninety2
Jul 22, 2008
568
9
The only weird thing that happens to my 4S is I'll use it lightly, but it down and come back a few minutes later and it's hot. Almost as if it's something in the background but it's not.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
thanks for the info.
28,365
5,506
Not recommended by whom? I don't believe Apple has stated this. Do you have any documentation to back this up? I do it every day and it hasn't damaged any of my iPhones.
RoofMonkey
Jun 21, 2010
8,867
2,047
Not recommended by Apple? Do you have any documentation to back this up? I have never heard that using an iPhone while it is charging is not recommended. I do it every day and it hasn't damaged any of my iPhones.
You would think of that were the case it would be in the Important Product Information Guide or even in the charging the battery section of the iPhone user guide... Found nada in either of them, which we ready knew huh? :D
Kylezert
Dec 7, 2011
17
Orange, California
No I was just saying that in my experience that my phones batteries that they seem to go bad faster than if you don't use it while it's charging. There are no immediate harmful effects but it will affect it over time.
28,365
5,506
I think that's a hasty generalization and there are too many variables to prove that it is true.
Kylezert
Dec 7, 2011
17
Orange, California
I use temperature gauges and you can't tell me that over time if your phone heats up to 98 degrees and the charger heats up to 120 degrees that there is not going to be any damage you would have to be ignorant if you think that is good to subject your phone to that!
