Pages
Edwin Walker
Oct 10, 2014
49
Hi all
I have recently installed pages on my iphone 5S
I have pages with documents on y macbook pro
But there is a document created on my mac that wont appear on pages on iphone. The other document created using word does appear on both devices
Am i going mad??
Lol
Rafagon
Dec 7, 2011
7,566
1,254
45
Miami, Florida
Hi all
Am i going mad??
Lol
You are probably not going mad, but I do not have the qualifications required to make an accurate assessment about your mental health.
As far as your issue with the document in question, are you 100% certain it is saved to iCloud and not to a local folder on your MacBook Pro's hard drive?
Here's how to check:
Open the document in question using Pages on your MacBook Pro. Open the File menu. Press and hold the Option key, which will change the "Duplicate" command in the File menu to "Save As…" as long as that key is held down. Click on "Save As…" and make sure the location you're saving to is iCloud (see screenshot immediately below) and not Documents or Desktop or some other local folder on your MacBook Pro. Re-save to iCloud if in fact the document was previously saved to your hard drive. The document should then be visible on Pages on your iPhone 5s.
Please reply if you require further assistance.
