Palm Desktop contact info to iPhone
FASN8N
Jun 30, 2007
Atlanta
Has anyone done this on a XP PC?
I have all my contacts in the Palm Desktop and don't know how to get them to the iPhone?
MarieM
Jul 2, 2007
35
I imported the contacts/calendar to MS Outlook since I knew that was supposed to sync. Then synced using iTunes. Worked like a charm.
dbw
Jul 24, 2007
How did you import them? I don't seem to find a format for the data that is compatible between Palm Desktop and Outlook.
Thanks for your help.
DBW
FASN8N
Jun 30, 2007
Atlanta
DBW
I had to export each contact to a vcard and then import the vcard into outlook. Not the easiest but better than retyping all the contacts in outlook!
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
or you can do CSV (Comma Separated Values). Make sure you double check the format before you sync... A lot easier to fix on a 'puter that iPhone.
iLawyer
Jun 30, 2007
44
Jersey
Would this work?
Not sure if this would work. Uninstall palm desktop and all files from computer. Reinstall palm desktop cd and choose to sync with outlook instead of palm desktop. Now all your contacts should be in outlook. Then sync iPhone. Just an idea.
