Pandora++ for iOS 13
Kevin Barnes
Jul 23, 2019
19
Pandora is the best online music application if you live in the US. It not only a music app but also includes live radio. So you don't have to be boring anymore. You can listen to your favorite music channel with favorite music. How amazing is that right? But as I mentioned earlier this app could only use if you are living in the US. Because they restricted it to the other countries. But you know what, there are always solutions for every problem. So the people who live outside the US only have to use a VPN which is connected by a server in the US and download Pandora from the app store. But today we are going to talk about Pandora ++ which is considering as a modified and tweaked version of the original app. So let's see how to download Pandora ++ for your latest iOS 13.
Features of Pandora++
  • If it is a free app you could not avoid the advertisements which are so annoying. But this modified version is Adds free even if the app also completely free to download.
  • The streaming can be considered as the highest quality.
  • You can play music offline as well.
  • There is no more unrestricted access to anything all are accessible and not to mention the skipping is unlimited.
  • It won't be timeout after 180 minutes. It will work for 24 hours.
  • The application is fresh and clean just like the original application. You won't find a difference.
There is a number of premium features in the modifies version rather than the original app. So it is worthy to give a shot. Even if it is a tweaked app which is essential a Jailbroken iPhone or iPad for the installation we are going to talk about download it without jailbreaking. So it is more than worthy, don't you think?
Download Pandora++ for iOS 13
  1. We have to use a third-party app store such as Tweakbox for the task. Download it and install it on your iPhone or the iPad which runs iOS 13.
  2. Then Go to Settings --> General --> Device Management --> Trust --> Select the profile. This will authorize the profile.
  3. Now it's ready to download Pandora++ in your iDevice.
  4. Open the Tweakbox and go to the app section.
  5. Next click on the Tweaked apps.
  6. There will be a huge amount of modified apps. Find Pandora++.
  7. When you find it just tap on it and it will start the installation.
  8. Then you will see a warning message but it doesn't matter. Just ignore it and click installation.
  9. Now you have to wait until the installation is finished.
  10. You will see the app icon on your home screen once it finished successfully.
Note: Using this kind of application, you can download Cydia app store also. Just follow the same instructions and it will be downloaded to your iDevice.
Bottom Line
Ios 13 was released recently but we do not have a jailbreaking method to it yet. So how we can download great apps like Pandora++ which is a modified version of Pandora? It's just so easy with Tweakbox and you do not need any kind of jailbreaking. So it is safe don't worry.
