Pandora
May 12, 2008
New Jersey
I have a unlocked iPhone with tmobile. Is there a way for me to get that program "pandora" on my phone without it locking up?
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Unless it's available via Cydia or Installer then you cannot get it from the iTunes App Store without upgrading to at least Firmware 2.0.
Saurabh
Sep 5, 2007
152
VA
Well cant you unlock the older iPhone on 2.0.0? Pandora is alright, i really like LastFM and Tuner Internet Radio ( Not free )
iChristian
May 28, 2008
315
thats the bad thing about jailbreaking phones. you cant get all these great apps on the iTunes store. some of them are absolutely SENSATIONAL and these other apps you see on installer may be free, but they're obviously not as good as these apps from the iTunes app store that u can download for as little as $10 or even free! but yes, if you want it on another network like tmobile, you just have to accept the fact that you wont get to use the apps from the iTunes store.
I just started using pandora. Really like it. I don't have great signal so it lags sometimes. But I have a question about incoming calls while listening. No calls come in. I'm on edge not 3G. Is this normal? If so that kinda sucks.
psylichon
Oct 31, 2007
16,591
751
41
Philly
Yes, this is normal. Unfortunately Edge does not support simultaneous voice and data, so if you are using the data channel when a call comes in, it will go straight to voicemail. 3G alleviates this issue.
ZR_Yancy
Jul 11, 2008
3,982
737
Edge doesn't allow voice and data at the same time. 3G does.
ivantwilliams
Jul 14, 2009
1,546
218
So will 3G mute Pandora when a call comes in?
syknes
May 5, 2008
22
Anyone having an issue where pandora will crash after about 4-5 songs played?
Babyt
May 24, 2010
1,013
64
Yes. And mine is taking well over 5 minutes to even load with full bars and 3g on. :/
swampduck
Oct 19, 2007
164
not having the loading problems, but yes crashing after about 3 songs for me.
btitus
Apr 7, 2009
501
26
North Carolina
No problems here fortunately. Loaded and playing within 20 seconds on WiFi
syknes
May 5, 2008
22
Thanks for the replies. Glad to hear that I'm not alone with this one.
eye-Fone
Jul 5, 2008
1,024
14
Sunny, southern California.
No multitasking (sometimes)
No crashes, but longer load times and when I task-switched to look at an email message, it stopped playing (didn't multitask). :( That only happened a couple of times out of many, fortunately.
syknes
May 5, 2008
22
Yes, the app switching cause it to stop playing as well. Forgot to mention that.
Libuff
Aug 13, 2010
35
theres also a bug, where when you get a notification (email for ex.), the audio normally "ducks" for the new mail sound... but then, it "ducks" for an additional 2 seconds, about a second after that... it also occurs when my GPS app tells me an instruction, it ducks twice..
its so annoying, i no longer use pandora...
imotionb18
Jun 15, 2010
458
Houston, Tx
I've been having issues all day. I can't get through more that three songs without it crashing. I hope they have a fix for it soon.
