Pandora?
snowrider221
Jun 27, 2007
anyone heard any news on whether there are plans to port pandora for the iPhone? Or even add it as an app? You cant currently use it due to it running on a flash interface... :(
That would be the best iPhone app
Regnad
Jun 27, 2007
19
I agree that it would be the best app. I listen to Pandora with a Squeezebox at home and having it always available would be amazing!
To be clear, it would require Flash support and nothing else?
Hoping...
snowrider221
Jun 27, 2007
Hoping...
yeah I think the two solutions would be an update that allows flash support, or If pandora coded a port of the flash version that could run on the iPhone
adam2046
Aug 18, 2007
Unlikely...
It is unlikely you'll see native flash support on the iPhone (or very many other mobile platforms) any time soon. The reason is because flash is a very client-intensive endeavor, requiring a decent amount of processing capability to function properly, particularly fp9. Youtube makes it work (afaik) by delivering the content to the iPhone in H264, which is decoded by Apple's hardware H264 decoder (coming soon to an ipod near you). H264's Baseline profile (1.3) is relatively light on the client side, decent for mobile platforms. Ideally, Pandora should (and probably will) shoot for this type of setup, as H264 seems the likely choice for mobile media in the next 12 months, especially on Apple devices, since they're planning on sticking their hardware decoder in all their next-gen products.
Regards
Adam
billchase2
Jul 22, 2007
33
i agree, it'd be a great app/webapp! i used to have it on my old sprint phone... hopefully they'll bring it to us iPhone users as well!
ootunes
May 16, 2008
Flytunes is pretty awesome (seriously, and you can't beat free!), if they happen to have the station you want... or the podcast you want (they are getting a lot more, which is good!), however, the OP asked about Pandora, which flytunes doesn't do... (flytunes also doesn't stream from last.fm, seeqpod, lala, mp3tunes, or your own iTunes library, or album art, or let you rate your tracks, etc.) So, imh(and biased)o, you get what you pay for (well, maybe a little more in both cases)..
Just use flytunes.fm. 375+ channels, video podcasts, and it's FREE.
iTrey.Bates
Jul 9, 2008
106
Texas
yes pandora is the best radio app ever..ive been using it on my computer for about 2 or 3 years..make your own personal stations...no commercials...who can beat that :laugh2:
dturner
Dec 15, 2007
5,725
Louisville, Ky.
I installed Pandora on my 3G. When I click on the icon I get the splash page for a second and it goes away.
Any suggestions?
Have you done the iPhone update yet? If so, and you still have the problem I would delete it from phone and iTunes and download it again. Worth a try.
mletang
Jan 23, 2008
120
NYC
www.NYCpetforum.com
Yes I did the update, and everything works fine. I love this Pandora, but I'm not so sure about the 3G yet. :eek:
are your other apps working fine? did you install it directly through the phone or through iTunes on your computer?
uninstall pandora, resync. Then download pandora through iTunes on the computer and sync again.
jUeLz23
Sep 4, 2007
350
u ahve to put your username and password in..
go to the Settings of the iPhone go all the way down and ull see Pandora..
enter it there should be good.
