Pangu 9.2-9.3.3 Jailbreak on the Way
liberated
Jul 19, 2007
3,237
487
Great just in time for iOS 10 to make it semi-irrelevant but I guess I'll be jailbroken for another month or two :/
Dec 15, 2008
5,386
340
27
Pensacola, FL
If you would like to try to jailbreak your iPhone for iOS 9.3.x without your computer, go to the link below from your iPhone.
- Press install and then install and it'll install an app.
- Before opening the app, turn off find my iphone and turn on airplane mode.
- Also go to settings-general-device management, and click what's in there and trust it.
- Then open the app, click the circle, lock your device and then it should popup with notification, unlock device and it's installing jailbreak.
@Napoleon PhoneApart Did I miss anything?
If you reboot device, turn off find my iphone and on airplane mode and redo the steps of opening the app etc.
https://totoateam.com/pangujb/
Napoleon PhoneApart
Jun 19, 2007
33,450
4,536
Upper Marlboro, MD
It was a little tricky for me. I almost gave up on it, but it finally worked.
Napoleon PhoneApart
Jun 19, 2007
33,450
4,536
Upper Marlboro, MD
Most of my tweaks are working fine on the new jailbreak on my 6s Plus.
App Admin
Barrel
BetterFiveColumnHomeScreen
BetterFiveColumnDock
Bioprotect
EqualizerEverywhere (Woohoo!)
Facebook++
Filza File Manager
Mikoto (can't get custom status bar text working, though)
Minimal Hosts Blocker
MulitIconMover+
Pull to Respring
RevealNC 9
Speed Intensifier (can't blacklist individual apps yet. Probably needs a PreferenceLoader update)
StatusVol X
Safari Downloader+
liberated
Jul 19, 2007
3,237
487
Important information from the developers:
Regular Apple IDs (not dev accounts) only have a 7 day signature. This means that the jailbreak app will not work after 7 days, and will need to be reinstalled.
What does that mean?
It does not mean you lose your jailbreak after 7 days. What it means is that, if you reboot after a week, you will need to reinstall the app to un-semi-tether your phone. Currently, if you reboot, your phone boots back into a regular, non-jailbroken state. To re-jailbreak, you simply run the PP app and it gives you write access again. If 7 days have passed, you won't be able to run the app (it won't even open).
You will have 3 options at this point. Either 1) run the jailbreak tool on your computer again, 2) sign the application yourself and push it to the device with something like Xcode or 3) use a website that is currently hosting a profile and the app itself, such as iOSEMUs.
This a limitation placed by Apple, not Pangu. It is possible that in the coming days/weeks a fix arises, but for now there is a one week reinstall needed.
Rafagon
Dec 7, 2011
7,566
1,252
44
Miami, Florida
If I may be honest, I'm back unjailbroken. I was getting errors when installing many tweaks. I was being sent to safe mode when getting emails inside of an app or logging into Twitter etc. Also now the website is down.
I can't say I'm surprised. A jailbreak solution packed and delivered through mobile Safari by a group who call themselves "Totoateam"? Why would you trust your device to such a sketchy-sounding piece of software? I know you went back and undid the damage, but how do you know they didn't peek at and possibly even "borrow" your private data during the short time you allowed them to set up shop on your device?
Heck, I don't even trust Apple with their iOS 10 Beta Thingamabob. Apple!
Dec 15, 2008
5,386
340
27
Pensacola, FL
I'm not worried to be honest. I'm jailbroken again.
liberated
Jul 19, 2007
3,237
487
From Pangu:
2. Important! Be cautious, incompatible/untested tweaks may brick your iOS devices
Due to the model change of jailbreak, some tweaks may not be able to work on iOS 9.2 – iOS 9.3.3, and even brick your iOS devices. Be cautious with the tweaks you want to install, and make sure you already made a full backup of your iOS devices.
Be careful everyone!!!!
Rafagon
Dec 7, 2011
7,566
1,252
44
Miami, Florida
From Pangu:
What was number 1?
