Paths & Various Mods
Dec 10, 2007
710
blacked out
I thought I'd start a thread with some of the more common paths and mods as the currently stickied thread is a bit outdated. If I've screwed anything up or you know of a better way to do something I've listed, please PM me so I can make corrections, that way we won't have conflicting information in replies. I'm just scratching the surface here, so feel free to reply with additions!
SMS Sounds Mod
/System/Library/Audio/UISounds/
iTunes can convert your audio file, be it mp3, wav, etc. to .aiff.
Open iTunes
Pull down the edit list from the top
Select preferences > advanced > importing
Select “import using aiff”
Then right click on the audio file and select open with iTunes.
Once the file is in iTunes (or if it already was) just right click on it and select convert to .aiff
Now delete that converted file to the recycling bin
Drag it back out of the recycling bin and onto your desktop
rename the file extension from .aif to .caf
Then you'll need a SSH client to transfer the file to the proper directory. That is here: /System/Library/Audio/UISounds/
The 6 apple-created SMS sounds are as follows:
sms-received1.caf = Tri-tone
sms-received2.caf = Chime
sms-received3.caf = Glass
sms-received4.caf = Horn
sms-received5.caf = Bell
sms-received6.caf = Electronic
For this to work the name must be the same as one of the files above. So you'll want to pick one of these to replace. For example, if you decide to replace Electronic (which you should, cause it sucks) you'll want to rename your converted .caf file to: sms-received6.caf.
Then, using your ssh client, drag your .caf file into /System/Library/Audio/UISounds/ (you’ll want to overwrite the tone you’re choosing to replace). That’s it!
Please note that the SMS name will not change. So if you replaced Electronic with your own custom tone, it will still say "Electronic" in the menu, but will play your custom tone. You'll need to reboot the phone for the change to take place.
Summerboard Themes
/var/mobile/library/summerboard/themes
To modify a theme with your custom icons, wallpapers, docks, etc., double click on the theme directory in the path above and you’ll see the various files. To replace the dock simply drag in the new dock image (overwriting the old). Your new dock image must be named exactly as the original is in the theme directory i.e., Dock.png.
Icons and wallpapers follow the same naming convention in their respective folders.
vWallpaper mp4(s)
/private/var/mobile/media/skrew/videos/
Drop mp4(s) into the videos directory in the path above.
installer source: http://i.danstaface.net
Image file Locations
Homescreen
Calculator Icon
/Applications/Calculator.app/icon.png
Maps Icon
/Applications/Maps.app/icon.png
Calendar Icon
/Applications/MobileCal.app/icon.png
Mail Icon
/Applications/MobileMail.app/icon.png
iPod Icon
/Applications/MobileMusicPlayer.app/icon.png
Notes Icon
/Applications/MobileNotes.app/icon.png
Phone Icon
/Applications/MobilePhone.app/icon.png
SMS Icon
/Applications/MobileSMS.app/icon.png
Safari Icon
/Applications/MobileSafari.app/icon.png
Camera Icon
/Applications/MobileSlideShow.app/icon-Camera.png
Photos Icon
/Applications/MobileSlideShow.app/icon-Photos.png
Clock Icon
/Applications/MobileTimer.app/icon.png
Settings Icon
/Applications/Preferences.app/icon.png
Stocks Icon
/Applications/Stocks.app/icon.png
Weather Icon
/Applications/Weather.app/icon.png
YouTube Icon
/Applications/YouTube.app/icon.png
The Dock
/System/Library/CoreServices/SpringBoard.app/SBDockBG2.png
Locked Screen
Slider Bar
/System/Library/CoreServices/Springboard.app/bottombarknobgray.png
Unlock Mask & Text
/System/Library/CoreServices/Springboard.app/bottombarlocktextmask.png
/System/Library/CoreServices/SpringBoard.app/English.lproj/SpringBoard.strings
Global
Color or picture of ringer background when you used volume keys
/System/Library/CoreServices/SpringBoard.app/hud.png
Alert bubble for calls, sms, etc.
/System/Library/CoreServices/SpringBoard.app/SBBadgeBG.png
Top Background where the signal bar is
/System/Library/CoreServices/SpringBoard.app/FST_BG.png
Battery
Charging Screen
Battery Backround
/System/Library/CoreServices/SpringBoard.app/BatteryBG_1.png-BatteryBG_17.png
Top Info Bar (signal strength, battery, etc.)
Carrier Logo
This seems to be where they live on 1.1.4
/System/Library/Carrier Bundles/ATT_US.bundle
/System/Library/CoreServices/SpringBoard.app/FSO_CARRIER_ATT.png (lighter one)
/System/Library/CoreServices/SpringBoard.app/Default_CARRIER_ATT.png (darker one)
Signal Strength
/System/Library/CoreServices/SpringBoard.app/FSO_0_Bars.png-FSO_5_Bars.png
/System/Library/CoreServices/SpringBoard.app/Default_0_Bars.png-Default_5_Bars.png
Bluetooth
/System/Library/CoreServices/SpringBoard.app/FSO_Bluetooth.png
Background (bar color) HomeScreen
/System/Library/CoreServices/SpringBoard.app/FSO_BG.png
Background (bar color) Lock mode
Background (bar color) All other screens (Text, Safari, Mail, etc.)
/System/Library/CoreServices/SpringBoard.app/default_BG.png
WiFi Bars
/System/Library/CoreServices/SpringBoard.app/FSO_0_AirPort.png
/System/Library/CoreServices/SpringBoard.app/FSO_1_AirPort.png
/System/Library/CoreServices/SpringBoard.app/FSO_2_AirPort.png
/System/Library/CoreServices/SpringBoard.app/FSO_3_AirPort.png
/System/Library/CoreServices/SpringBoard.app/Default_0_AirPort.png
/System/Library/CoreServices/SpringBoard.app/Default_1_AirPort.png
/System/Library/CoreServices/SpringBoard.app/Default_2_AirPort.png
/System/Library/CoreServices/SpringBoard.app/Default_3_AirPort.png
Power On/Off Screen
The logo (only shows when it starts to minimize)
/System/Library/CoreServices/SpringBoard.app/Applelogo.png
Power Slider
System/Library/Frameworks/TelephonyUI.framework/bottombarknobred.png
Calculator
Background
/Applications/Calculator.app/CalculatorBackground.png
Screen Background
/Applications/Calculator.app/LCDBackground.png
iPod
Rating Stars
/Applications/MobileMusicPlayer.app/star_filled.png
Phone
Keypad
/Applications/MobilePhone.app/BarDialer_Sel.png
SMS
Input Field (Bubble where you type you're text message)
/Applications/MobileSMS.app/BalloonInputField.png
Baloon 1 (Bubble where sent text messages are)
/Applications/MobileSMS.app/Baloon_1.png
Baloon 2 (Bubble where received text messages are)
/Applications/MobileSMS.app/Baloon_2.png
Bottom Bar Background (Background behing the text input field)
/Applications/MobileSMS.app/MessageEntryBG.png
Safari
Url Bar
Idle
/Applications/MobileSafari.app/Url.png
Inactive
/Applications/MobileSafari.app/UrlInactive.png
Active
/Applications/MobileSafari.app/UrlProgress.png
Mail
Trash Can for deleting mail
/System/Library/PreferenceBundles/MobileMailSettings/trashmbox.png
24trepid
Jan 13, 2008
502
They're all WRONG.........
No, just kidding.........LMAO
Thanks for all the info....:cool:
Good idea. We had a very similar thread started by a member that left, but it's long gone one. My vote goes for sticky.
- John
Eragon
Jan 8, 2008
3,056
50
Frederick, MD
Great thread. :)
Out of curiosity, I was checking a theming tutorial over at Hackintosh.com. The tutorial was directed at firmware version 1.1.3. With each firmware update, are we seeing changes in path names? In other words, will the information provided above not be valid for 2.0?
Dec 10, 2007
710
blacked out
Good question, Eragon.
I can say for certain that none of the paths changed when I updated from firmware 1.1.2 to 1.1.4. It seems unlikely that they would redesign the wheel with 2.0, but certainly anything is possible. Just seems like that would be a lot of unnecessary rework of some pretty solid file structures. That's not to say that some individual items might get a new home (or path) with the addition of new bells and whistles. Can't wait to find out! :)
Paths are the same in 1.0 - 1.1.2. They are also the same in 1.1.3 and 1.1.4. This is because 1.1.3 changed the default user from root to mobile. So if a file was located in /var/root/Library in 1.1.2, it would be located in /var/mobile/Library in 1.1.3.
- John
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Hey Freaky, great write-up. Just noticed a few small errors.
/Applications/Calculator.app/Baloon_1.png
/Applications/Calculator.app/Baloon_2.png
Should the app be MobileSMS.app for all 4? It's a small thing but it'd be kind of funny for someone to try and put a chat bubble into their calculator.
papabro
Jul 23, 2007
101
MA
Carrier Logo
I am trying to update my carrier logo and I am not seeing them in this directory. I agree they were there prior to 1.1.4. Can someone let me know where they are now?
thanks
dito
Sep 28, 2007
79
i just built a new pc and am trying to transfer my iPhone info. i got most of it, but can't find my NOTES, anyone have any idea where i can find my notes from the old PC to copy to the new one? Thanks!
Rip
Oct 23, 2007
636
Northern England
The best solution is to sync and then back up with your old PC.
Then transfer across the entire Apple Computer folder (/Documents and Settings/Application Data/Apple Computer) to the new PC.
Make sure the iTunes version is the same on both PCs before you begin.
iTunes will then work just as it did before and not even know that you're on a different PC.
All of your data and apps will be just as you had them before.
dito
Sep 28, 2007
79
i guess i partially already screwed up. my phone WAS working fine, and synced to the new PC. yesterday my iPhone totally crashed, went from working to the "sync with iTunes" screen. i was in such a panic to restore my iPhone, i restored through iTunes and figured i migth as well update to 2.2.1 (i was on 2.1). so now i have almsot everything back onto my iPhone (had to recreate playlists, import contacts and calendar, etc. the only thing i can see missing is the notes. is there any way to retrieve it from the old pc without having to reinstall the old software onto the iPhone , then resore on old pc, the upgrading, then jailbreaking/reinstalling everything AGAIN? Thanks!
iDom
Feb 23, 2009
Ok, so does anyone know the directory path where the iPhone stores the sync'd photos that are NOT in the Camera Roll.
Reason I ask is I've recently started using Cydia's File2Mail, so now I can email multiple docs in the same email. Yesterday I attached & successfuly sent a Word & Excel file in the same email. I had these files already stored in my TextGuru folder and found the directory path through MobileFinder, so I now know where to point File2Mail in the future to attach TextGuru notes and other MS Office files stored.
Unfortunately, I can only find Camera Roll photos at /var/mobile/media/DCIM/etc., but I have hundreds of other photos sync'd which I'd like to send more than one per email whenever I need to.
Anyone found this directory path to non-Camera Roll photos?
