PawnAge problem
isal
Mar 22, 2009
136
Toronto
So I have OS 10.5.6 and I downloaded the DFU patch from Hackint0sh and patched it.
Now using PawnAge I am able to get into the DFU mode successfuly (Its displays on the window "You're In!") but I still get an error on iTunes "Detected an iPod...." and then there is nothing under the "Devices" tab. I switch on the phone again and try to restore it using the custom firmware but it gives me an error.
Is it a problem with my Mac or iPhone. I am running 2.2.1 on BB 20.03.30. Should I just do it on a windows?
Thanks a lot!
P.S. I just want to jailbreak.
28,365
5,507
Just use a PC if you have access to one. I ran into the same problem with my Mac, so I JB on my PC and then sycn'd it with my Mac. You could try using a USB hub on the Mac first if you want.
