PC user AT&Tempts iPhone interface
RickGRosa
May 20, 2009
Brand new iPhone, longtime PC user currently w/ Windows XP. Is there a simple website on learning how to download from PC to iPhone 3G? I'm having a particular problem downloading iTunes to PC. Thanks. RickG
iStealth
Nov 5, 2007
421
Like what specifically are you having a problem with? The download itself, or the install, or what? Should be very simple. Go to Apple.com, download iTunes, let it install, then plug in iPhone.. Not must more complicated than that.
PepeRB29
Mar 21, 2008
1,500
8 mile
if you can't even download iTunes onto a pc then you have issues larger that we cannot help you with
PapaST
458
The basics of how it works is something along the lines of...
Download iTunes and install to PC.
In iTunes point/import your songs (that are on your PC) to you iTunes Library.
Plug your phone up to you PC via USB cable/docking station and let iTunes recognize and you'll see it listed on your left pane.
Then select the phone and you can manipulate what goes on it from there.
Typically for music I create several playlists then on the iPhone pane I select which playlists I want on my phone.
Let us how we can help.
