PdaNet
MaverickC17
Dec 29, 2007
178
Is it possible to tether another iPhone(Edge) or iPod Touch to my iPhone 3G with PdaNet?
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
I was playing around trying to tether my PSP with it also and that won't work either, although you can create ad hoc networks they are PSP specific.
jerrettpaul
110
Denton, TX
I can't seem to establish a connection with PDAnet...what am i doing wrong?
psylichon
Oct 31, 2007
16,591
751
40
Philly
First mistake: not enough details. I don't use the program, but whoever does is probably going to need a bit more to go on.
PepeRB29
Mar 21, 2008
1,500
8 mile
yes the search button works awesome.
i use it extensively, have you ever got it to work or what? sometimes it can be a little interesting to figure out how to work, but it always does. pm me with more details and i'll get you squared away.
jerrettpaul
110
Denton, TX
Hey guys!
thanks for all of the replies! with a little poking around i finally figured it out!
wildonrio
Jul 4, 2007
2,002
Provo, UT
I need some help too! Here's what I do:
1. Make a new ad hoc connection on my Vista PC with "iPhoneNet" as the name, no encryption.
2. Log onto "iPhoneNet" from my phone. The icon at the top changes to a WiFi signal but then changes back to a 3G symbol.
3. My computer logs on to "iPhoneNet", but does not load webpages. (If you know Vista, it gives me the two computers, but not the two computers with the globe between them, which indicates that you have Internet access.)
Is the icon at the top supposed to stay as WiFi even though my computer will be using my phone's 3G signal? And if it's supposed to be a WiFi symbol, why is my phone switching back to 3G? I check my WiFi settings and it says I'm logged onto "iPhoneNet" but the 3G symbol is still at the top.
Arkapigdiesel
Jan 8, 2009
29
Northwest Arkansas
1. Click on your active connection in the Windows task bar and choose "connect or disconnect"
2. Double click your ad-hoc network that you created
3. Go into the wi-fi options of your iPhone and choose the ad-hoc network name you created on your PC
4. Go into the PDA Net app and allow it to run and connect with your PC
Once you connect via your ad hoc network and establish the connection through PDANet, your wi-fi signal will go away and you will then be using the AT&T network (that's how it's supposed to work).
wildonrio
Jul 4, 2007
2,002
Provo, UT
Ok thanks for your help. I go into PdaNet and it says "PdaNet WiFi Router need to initialized first. Please restart your iPhone." So I restart it and my phone connects to my home WiFi automatically on a restart so I have to manually choose the ad-hoc network again. Then I go back to PdaNet and I get the same error message to restart my phone.
wildonrio
Jul 4, 2007
2,002
Provo, UT
Can multiple computers log onto PdaNet if I use an ad hoc network? If so, then I'd much prefer that.
Survivor61
Jun 26, 2007
70
Anyone tried this today? Seems I can only use the web browser now, anything that uses a different port other then 80 won't work. Tried under OSX and Windows. It worked last week just fine.
Wonder if AT&T is blocking stuff now due to 3.0 or whatever.
28,365
5,507
Yeah, I just paid the $29 for it since the 10 day trial expired. Great app.
