Persistent updates but never shows up
Smarty2600
Apr 23, 2011
344
11
I'm running ios 6 and my App Store always shows a 2. Like I have 2 apps to update but it doesn't show any updates. And I have actually updated some apps since the problem appeared but the 2 goes away sometimes and then always shows up again.
Sent using iCafe app
Dec 15, 2008
5,386
340
27
Pensacola, FL
That is strange, but has happened to me before. If this does happen again, you could try to fully close the App Store and reopen it to check for updates. Or you can update the apps via iTunes and sync your iPhone.
28,365
5,506
Syncing your phone with iTunes should fix it.
Kriss
Jun 8, 2008
598
121
43
Cape Cod
voyager01.deviantart.com
I have the same exact issue. Running iOS6 jailbroken. It shows that two apps have updates, when I go into the updates, there's nothing there. Other updates have come and gone but the alert for two keeps appearing. I have rebooted, synced done every update. I wonder if it's just telling me that iOS7 is available.
28,365
5,506
Certain jailbreak tweaks/apps can cause this. I found a thread on another forum where uninstalling NoLockScreen in Cydia resolved the problem for one person.
