Personal Hotspot not working
Bullgod
Oct 15, 2012
I turn my hotspot on, and it says its on but nothing can detect it. I've tried my laptop, my blackberry and another iPhone none of them show it. Is this an iPhone problem or a Rogers wireless problem? Or possibly a "me" problem ...lol
Cent from my iPhone using iCafe app
jmp316
Jul 10, 2008
1,048
141
Sometimes I find that you have to toggle the Personal Hotspot on/off switch a few times with the other device on to get it to work...
Bullgod
Oct 15, 2012
That's what I've been doing. Sometimes it connects but says Limited Access on my laptop.
Bullgod
Oct 15, 2012
Mine is definitely an iPhone problem because I've tried with three different devices at the same time and none of them detected a hotspot until I toggled my iPhone hotspot off and on several times.
If I connect my iPhone to my laptop with the lightning cable it tethers fine but its just not as convenient.
Dex Pt'Chang
Jan 15, 2012
37
Warburton, Victoria, Australia
I had a lot of trouble connecting my pc. The Blue Bar was saying connected. I could see throughput but it wouldn't go online. In my case I used USB, but you may find this useful.
This is what I did:
  • In settings under Safari on my 4s , I cleared all cookies, history and I set accept cookies to ALWAYS
  • Then on the PC I created a 2nd LA connection in network connections. The 1st is connected to a router with WIFI but so far I have persisted with USB as WIFI seemed less likely but it may work now, I haven't checked.
  • I then opened properties of the LA connection 2 and hit the ADVANCED tab and checked "Allow other network uses to connect to this computers internet connection".
  • I then opened Settings in the 'Internet Connection Sharing' dialog and SERVICES tab opens. In this page there is a list of check boxes for internet protocols, DNS servers, mail servers etc. Check them all.
This time when I opened my browser it finally got online.I then opened the settings list again and there were some extra check boxes from some extra protocols.
Whatever that it found after it first loaded up google search page. It finally works. Who knows what did the trick, but now it's rock solid!
