Phone battery draining after factory reset. HELP!!
Johnlennon78
Dec 25, 2011
43
Hello all,
I just recently factory resetted my iPhone 5S and noticed that the battery was draining in no time. I checked on setting-general-about and noticed that where it say songs/video/photo it keeps on saying loading... could that be the reason why it drains my battery?? If so how can I fix this since i resetted the phone twice now. I have included a picture if you can help
rugved1118
Sep 27, 2013
644
Screenshots aint getting dwnloaded... could you please resend ?
5,580
I can see the screenshots from the first post fine. They might be blocked from the other person who replied because he's using a forum app rather than the full site. The apps have limitations. Did you set the phone up from scratch after you restored it or did you use your backup?
Johnlennon78
Dec 25, 2011
43
I set it as new. Could that be draining my phone??
rugved1118
Sep 27, 2013
644
Agreed
rugved1118
Sep 27, 2013
644
Try hard booting your iphone and check again...
rugved1118
Sep 27, 2013
644
Hard boot :-
Hold down the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Johnlennon78
Dec 25, 2011
43
So it's not normal that it keep saying loading right???
5,580
Try unsyncing your songs, videos and music and check the battery life. Then sync them back on. Make sure you still have at least a couple GB free after syncing them.
Johnlennon78
Dec 25, 2011
43
Thanks for the Reply. Prob is I have no songs at all to be sync...
