Phone calls goes to voicemail when connecting to edge?
Fayewolf
Oct 10, 2007
62
I've missed several phone calls (that went directly to voicemail) while I'm checking email or using edge. I thought it would hault edge and let you answer the call?
This morning, i was checking email, (says connecting), and then after I was done, i have a voicemail that my phone never rung..
Is this true? Thanks!
Dragoro
Sep 9, 2007
140
Yep, its true.
psylichon
Oct 31, 2007
16,591
751
41
Philly
naaaaaaw, come on! It's supposed to have voice priority over data connex, right? I'm almost positive mine has been working this way...
420greg
Jun 26, 2007
845
Orlando, Florida
If you are on the edge network moving data your calls with go to voicemail.
This has something to do with edge not the iPhone. My blackberry did the same thing. I found out that surfing while waiting for someone to call was a bad idea.
ebp2kEM1
Oct 14, 2007
43
From the info I've read about this - AT&T (and presumably, most other GSM carriers) supports this function, but the hardware has to be configured to support it as well. It seems the GSM protocol that Apple chose to use, does not support getting voice calls while data is being pulled down.
It sucks. :(
tmoce
Oct 10, 2007
Let me get this right. When Edge is receiving signals (e.g. loading a webpage) the calls go to voicemail? All the time I have been browsing on edge I get interrupted when receiving calls, although I do not recall Edge being actively loading at the time of receiving calls. Just want to be sure
jwhcowan
Jul 5, 2007
29
Yes, when edge is loading a page, calls go to VM.
ebp2kEM1
Oct 14, 2007
43
I did a little more digging - and it looks like maybe this is a setting based on the cell tower you are connected to.
It seems that there are two standards, NOM 1 and NOM 2.
NOM 1 does allow voice calls to suspend data - i.e. - you gets your calls even in the middle of EDGE transferring data.
NOM 2 does not allow for this - EDGE data has priority and voice calls go to voicemail.
If you have a jailbroken iPhone and know how to launch the FieldTest App, do it and see what NOM you are connected to. Mine shows nom 2 - and i do not get voice calls when im actively pulling data.
Yep. It happens.
cdinca
Jul 4, 2007
397
Nailed it!
Tinman
4,334
183
Aridzona
As an FYI you do not need to be jailbroken to use FieldTest. Dialing [SIZE=-1]*3001#12345#* from the dial pad will bring it up on any iPhone.
Mike
[/SIZE]
ebp2kEM1
Oct 14, 2007
43
Mike
[/SIZE]
Thanks! I didn't know about that trick. :cool:
