Phone case / wallet
Outtahand
Aug 27, 2010
I am looking for a case or folio-type cover that:
1) can hold my iPhone while it is in the Lifeproof case
2) has pocket or two for ID and credit card
3) has a spot for a little cash
4) allows use of the phone while in the case
5) allows use of the camera while in it
Does such a mythical wallet/folio exist?
hmfc-1874
Sep 10, 2011
510
34
See I personally don't believe in them.
I tend to keep my Wallet and phone in different pockets, as there is less chance of you getting both nicked.
But with the wallet case, yank that and its killing one 2 birds with one stone.
  • Like
Reactions: RoofMonkey
Outtahand
Aug 27, 2010
I completely understand that risk. I plan to use this case only when "traveling light" -- bicycling, walk around the block, etc.
Marianne
2,326
Massachusetts
marianneschultz.com
I think finding a case to fit the Lifeproof is going to be difficult - every single one of the wallet-style cases I've seen so far will only accommodate a case-less iPhone. If that's do-able for you, Hex makes a new case that has everything else on your list.
Outtahand
Aug 27, 2010
Update: i did a bunch of Google searching. Found a page of a guy who did some research. He found that the HTC Rezound is the same size as the iPhone inside the Lifeproof.
I've ordered a leather wallet case designed for the Rezound. Hopefully, the page I foynd is accurate.
K
Kamlesh Kumar
Guest
I think you can ask Apple or any other iPhone case company to built such a customized case..there are many smaller businessses for iPhone cases in Korea which are looking for more innovative ideas, may be your idea can help them..please keep us updated as well.
Outtahand
Aug 27, 2010
Happy news!
I found a leather case from a company called Monaco. It is designed to fit the HTC Rezound. Turns out that phone is the same size as the Lifeproof case for the iPhone 4S. It fits perfectly!
I had to cut off one little clip on the case and it turns out to be a great solution!
