phone doesn't vibrate
May 19, 2008
i need help for some reason all of a sudden phone stopped vibrating vibrate settings are on and nothing
15,385
1,089
there's not a whole lot you can do here. First i'd try resetting all settings. If that doesn't work, try restoring (as a new phone; not from a backup). If you still have the problem after fully restoring your iPhone, it's time to talk to Apple about a replacement.
mdev05
Jun 13, 2008
19
Did you use your ear phones of late? It might happen because of that as well. This trick might work. insert and remove the earplug pin 10-20times into iPhone jack. This might work.
