Phone is stuck at USB & iTunes screen
Shanezam203
Dec 30, 2007
91
My iPhone is stuck at the USB and iTunes screen. I can turn it off, or put it in restore mode... But all the .ipsw files I have do not successfuly load or restore in iTunes with the shift button.
Any suggestions?
Thank you,
Shan e
Mar 30, 2008
5,126
Elizabethtown, Kentucky
That happened to me also when I started Jailbreaking
-The reason why it had happened to me was because my iPhone was not in DFU mode... make sure it is bro!;)
sefa93
Dec 28, 2009
19
hey i hope you can help me. My iPhone 3gs is stocked at the start logo because i downloaded an app from app store but it wont work and after i reboot it and now im stocked at the start logo.. i have tried to restart again and again but it wont work...my iPhone is jailbroken
HOPE YOU CAN HELP
Jun 12, 2009
970
27
after a little while of the iPhone booting, does it show a little swirly thing in front of the iPhone ?
28,365
5,506
Press and hold the home button and the power button at the same time for about 10 seconds. If it does not boot, you will have to restore it in iTunes.
sefa93
Dec 28, 2009
19
no there is not a swirle thing
and yes i had tried to reboot with home and power button but doesn't work
i am willing to restore but iTunes cant see my iPhone because (recognize it because my phone not start)
28,365
5,506
Put it in DFU mode first.
Jun 12, 2009
970
27
ok, turn off your iPhone, now, hold the home button, and keep holding it, while holding the home button, connect the USB cable, iTunes should recognize it, then restore from there
note :, make sure that the USB cable is connected in the back of the PC, its better like this since the USB is connected directly to the motherboard..
sefa93
Dec 28, 2009
19
how do i do on dfu mode, im not so good to that stuff so if you could explain it more detailed thanks
Jun 12, 2009
970
27
just do what i explained above, this should restore your phone, DFU mode is another method to try and restore the phone...
sefa93
Dec 28, 2009
19
ok is there another way without restoring
28,365
5,506
Search YouTube for a "How To put an iPhone in DFU mode" video.
No. There is no other way.
Jun 12, 2009
970
27
but you said you were willing to restore, now your not ?, well, if your iPhone just stays stuck on the Apple logo, and your jailbroken, it means that your phone crashed, and badly, the only option here left is to restore, i cant think of anything else..
sefa93
Dec 28, 2009
19
hej @mr.reggaeton72 it doesn't work there is written on iTunes that it coulld not connet to the iPhone software
Jun 12, 2009
970
27
what ?, i don't get it, whats the exact error that iTunes is giving you ?
sefa93
Dec 28, 2009
19
sorry i will restore it but, i did as you sad but iTunes write that it could not connent to the iPhone software sorry i
sefa93
Dec 28, 2009
19
the iTunes write this "could not connect to iPhone software update" sorry im not so good to english
Jun 12, 2009
970
27
well...mmm..i don't know what to say here..try restoring again and see what it says...
sefa93
Dec 28, 2009
19
it doesn't work with the dfu mode it show this "could not connect to iPhone software update"
Jun 12, 2009
970
27
ummm..listen, this may seem stupid but, are you connected to the Internet ?, cause that iTunes error only indicates that there isn't an internet connection..
