Phone running hot and short life battery
My apple gadgets
Jan 2, 2013
Just in case someone has problems with iPhone running hot and battery continues draining even when phone is not used, try reboot and reset. If it still doesn't work, try to think of the last app you installed before the problem appeared and delete it to see if it would work. I've installed google map app and the next day I started having the battery problem and the phone running hot while on standby. Once I've deleted the app, the problem disappeared. It's believed that if you have a problem app, it can keep running in the background and make the phone hot and drain the battery.
The worse case scenario, delete all the apps that you do not really need ( you will be surprised to see how many those are) and reinstalled app by app to identify and eliminate the problem one.
Hope this helps.
  • Like
Reactions: Nrevezzo
Docd
Oct 16, 2011
651
62
Most likely google map was running your GPS. I've noticed when running apps that require my GPS to be on all the time my iPhone will get hot and battery drains quicker.
liberated
Jul 19, 2007
3,238
484
You'd see the GPS icon if that was the case right?
Sent using iCafe app
Docd
Oct 16, 2011
651
62
Yes you should. But some apps (like passbook) just flash it for a few moments then turn off.
Docd
Oct 16, 2011
651
62
Mostly third party but Apple stock apps should do it too. I mostly use third party apps that require constant use of my GPS such as cobra and wazes.
