Phone shuts down by itself
Inkncraig
Jan 30, 2012
24
I took a screen snap shot form a app. I later tried to edit the snap shot and the phone just shuts down. The little Apple appears on the screen and the phone recovers pretty quickly, it does this over and over. What's the issue here?
Inkncraig
Jan 30, 2012
24
The basic editing software that came with it in the photography
System 5.1.1 - 4S
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Are you currently Jailbroken? What phone are you using? What app are you trying to edit your photos with? It may be a setting or a tweak/app from being jailbroken if you are.
I just read an issue you're having online, similar to yours.
https://discussions.apple.com/thread/3792390?start=0&tstart=0
Inkncraig
Jan 30, 2012
24
Its the 4S with the current updated software 5.1.1 It also did this with the old 5.0.1 software i am trying to edit a screen shot photo I took. It only does it with this picture. It does not do this with pictures that I used the camera with
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
You're saying you're using the editing program with a photo you put onto your iPhone? But it doesn't shut down when you use it with photos you took with the phone camera?
Seems like a known issue from what I am reading. Not sure if it's from the new iOS or maybe the photos being edited are not being accepted?
bikerboy
Jun 20, 2009
263
Ohio, USA
My phone is shutting off by it self as well, no reason what so ever, 5s , only happened after restore .
Today i decided that was it , having a skype voice call for over and hour, the phone has at least 80% battery left , the phone died , started it , died again, then bunch of restarts, hard rest couldn't work as the phone restarted it self while being rested, it ever restarted it self while doing Itune restore.
Advice is much appreciated, sorry to hi-jack this threat , didn't know if i was supposed to start another one or no, so this was the safest option.
Today I decided that was it , having a skype voice call for over and hour, the phone has at least 80% battery left , the phone died , started it , died again, then bunch of restarts, hard rest couldn't work as the phone restarted it self while being rested, it ever restarted it self while doing Itune restore.
Advice is much appreciated, sorry to hi-jack this threat , didn't know if I was supposed to start another one or no, so this was the safest option.
This is commonly referred to as "crashing." Occasional crashes are expected on iOS 7. A firmware update will solve it eventually. However, multiple crashes will require intervention now. I've had it happen several times on my 5s as well. Mine were usually cashed by the fingerprint scanner, so deleting my prints and adding them back in fixed it. I would try resetting all settings. If that doesn't work, restoring the phone should resolve it.
bikerboy
Jun 20, 2009
263
Ohio, USA
i did set up as new
changed phone name
didn't sigh in to iTunes account
restoring apps from Itune " on laptop "
bump'ed my contacts back on , hope it doesn't crash again
it's annoying
Thank you Europa you are helpful as always
bikerboy
Jun 20, 2009
263
Ohio, USA
It did it again, shut down so I started it again and it crashed at Apple logo
Connected it to charger kept on crashing for over a minute then I unhooked it and waited several minutes and now it's on again !
Advice please ....
Sent using iCafe app
bikerboy
Jun 20, 2009
263
Ohio, USA
If you are able to see the attached pics above is a couple of the diagnoses I got , contacted Apple support chat said they don't see anything wrong with iOS and that the phone needs to be sent to them ! As if I am not 10k miles away .
bikerboy
Jun 20, 2009
263
Ohio, USA
tried that, once the phone restarted and was connected to the laptop "macbook " it started restarting none stop, till taken off of cable , and put a side for a minute, i think it's time for dhl to take the phone back to the usa and a friend of mine take it to Apple store.....
unless if there is another advice maybe
Sounds like it's stuck in an infinite boot loop. If a DFU restore won't fix it, I don't know what would. I'd ship it back for replacement. Too bad there isn't an Apple Store near you.
bikerboy
Jun 20, 2009
263
Ohio, USA
is there a way of maybe retoring previous version of iOS and see if that fixes it ? i had no problem before " i don't remember upgrading " if there was an upgrade within a month and a half .
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
is there a way of maybe retoring previous version of iOS and see if that fixes it ? I had no problem before " I don't remember upgrading " if there was an upgrade within a month and a half .
Unfortunately you can't restore to a previous iOS such as iOS 6 anymore. Have you spoken with Apple or your phone carrier about the issue or issues you are telling us about?
bikerboy
Jun 20, 2009
263
Ohio, USA
my carrier has nothing to do with iPhones, plus i've bought the phone thro Apple.com , not the carrier nor a local store in Jordan , i meant maybe like 7.0.3 instead of 7.0.4 ?
