Phone will not turn on anymore.. Help Please!
merlconn13
Jul 19, 2007
52
have a 3gs and my battery was almost dead, i'd say about 20 percent or so. so as im on my way to work i was texting and it was fine. when i go to work to plug it in to charge, the phone was off and would not turn back on. not even after its been sitting on the charger for hours. hard reset does nothing. its just a black screen. theres no way the battery is shot. my original iPhone still works if i charge it. anyone have any ideas? thanks
merlconn13
Jul 19, 2007
52
not at all. the phone is just off and wont turn on no matter what. the only thing i can say that was odd before it happened was when charging with my charger it was saying the charging isn't supported with this acessory or whatever it says, but once i unplugged it and plugged it back in it would charge. also there would be delays from when pressing the on/off button to the screen actually coming on to the slide to unlock screen. it was off a few seconds sometimes. these both just recently started like a week ago
15,385
1,089
plug it in and try holding the home and lock buttons down together. give it at least 20 seconds or so.
merlconn13
Jul 19, 2007
52
trust me i've gave it over a minute. that didn't work
fearofnormalcy
Jul 8, 2010
1,742
118
New Port Richey, FL
www.facebook.com
I know you said there's no way your battery could be dead, but that's really what it sounds like.
Are you using a standard Apple cable/power cube to charge and/or connect to a power source/PC? That "unsupported" message seems odd. Also, had you recently upgraded the OS? Lastly, are you jailbroken?
15,385
1,089
Could be the logic board too. If a hard reset didn't work, I'm not sure there's much else to do apart from surgery.
merlconn13
Jul 19, 2007
52
not jailbroken everything is all normal. same with the chargers. either way i got an iPhone 4 today now here comes problem two: my back up from last week is on a diff laptop. all the usb slots just stopped working all of a sudden three days ago. how can i get this back up file to my other laptop so i can restore what i at least had up until this week
merlconn13
Jul 19, 2007
52
thanks a lot for the help. my only prob is my backup is 6.65 GB. i can't share the folder with the other laptop because i cant connect to anything. is there anyother way to do this. i have a dvd burner. do they even make a dvd-r that can hold that?
15,385
1,089
Your iPhone backup is 6 GB? Jeez.
Yes, you can get a dual-layer DVD-R that will hold ~8GB.
Lon
Jun 5, 2010
2,946
132
Alaska
Do you (or a friend) have any cloud based services (iDisk or Dropbox) that might accommodate your transfer?
Edit: Or Shared Files on the same network.
merlconn13
Jul 19, 2007
52
Do I need to be hooked up to the Internet or a network for those? Like I said every slot on this laptop is shot including the Ethernet slot, and so is the wireless card. All I have is a burner that will work.
Lon
Jun 5, 2010
2,946
132
Alaska
Well you've answered your own question. Burn onto DVD or remove the hard drive and get a USB hard drive reader to remove the data.
merlconn13
Jul 19, 2007
52
Ok everything is fine. I just lost whatever texts and pics I took last week which I can deal with. Next issue are my apps. I'm burning them onto a DVD just like I did the back up file. Can I just drop them into the new laptop folder and they will be recognized in iTunes?
15,385
1,089
In iTunes, go to file->add folder to iTunes,mand then choose the folder of apps on your DVD.
All you have to do then is make sure iTunes is authorized.
M
mafia_001
Guest
Or get a new usb cable slot.
mcquaid1
Dec 8, 2007
134
Ireland
Hi guys
A friend of mine who's not too technical have me his phone the other day to fix, it's been broken for about 6 months, just coming up with warning symbol indicating 'connect to iTunes', I've no idea what software this is running but would be reasonably old
Anyone any ideas on what the problem is?
Docd
Oct 16, 2011
651
66
Just a thought have you connected it to your computer and iTunes?
Sent from my iPhone using
5,578
That screen means the device needs to be restored on a computer. You can do this in iTunes on a Mac or a PC. Post back if iTunes doesn't recognize it or if you get any error codes during the restore and we'll advise you from there.
