Phonebook transfer
Ocala
Jun 14, 2007
79
Ocala, FL
Does anyone know if I'll be able to transfer a phonebook from my Nextel i605 to the iPhone? I have about 220 numbers in the phone and don't really want to enter them all again if it can be avoided.
I can get the numbers into excel spreadsheet, but I have no idea how I might need to engineer the spreadsheet to properly move it to the phone.
The i605 is a bluetooth phone.
Also, does anyone know how the iPhone might work with my Pioneer bluetooth stereo? My Nextel makes calls but will not connect automatically. The AT&T Blackjack will connect automatically, but will not transfer the phonebook into the memory of the stereo.
Thanks in advance for any thoughts!
RchGrav
Jun 8, 2007
242
If you cen get them into a spreadsheet you can very easily import into Outlook (Most any version) and then sync it right back into the iPhone. It shouldn't be a problem at all for you. If its over your head, any half way decent computer tech can do it for you.
Good luck!
emerrill
Jun 14, 2007
126
The folks at the AT&T store can help you transfering
Ocala
Jun 14, 2007
79
Ocala, FL
Assuming that you are using a phone that has a sim in it, yes they could be transferred that way as well.
It DOES have a sim, but I thought the sim in the iPhone is internal - how would it be moved from the Motorola to the iPhone?
emerrill
Jun 14, 2007
126
No, it has a SIM tray, it can even be seen on the new photos on Apples gallery.
netshadow
Apr 21, 2007
40
Upstate NY
the sim
just make sure that you have saved (copied) your contacts to the sim card. I have a Nokia 6682 which does not do it automatically, you must manually copy them over to the sim. then they can just switch the sim to activate and transfer your contacts.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
If you have a Cingular/At&t sim card they can do this. IF you have a T-Mobile sim card, they can not.
IF you have MPT you can backup your calendar and phonebook to your computer or sync your phone with Outlook. Then when you plug in the iPhone, it will find the backed up phone book and calendar and load them on your phone.
