phonebook
in the flesh
Aug 12, 2007
Hello everyone,
I just got an iPhone and I have over 350+ contacts on my blackberry and I'm trying to transfer it to my iPhone but I don't know where to begin, at the Apple store they said it was very simple, but I'm having a lil trouble is there an easy way to do this?
Marianne
2,326
Massachusetts
marianneschultz.com
some details would be helpful so we can point you in the right direction. are you using a pc or a mac? what operating system are you using? what sync software do you use to sync your blackberry to your computer (if any)?
P
phoneme
Guest
No sure how to do that one. I personally have a blackberry and iPhone and I use them both what I did was to put the contacts in the black berry into my iPhone manually but then again I did not have 350 contacts.
in the flesh
Aug 12, 2007
I am using a PC, Windows XP HE, and I'm not using any sync software
Standog
Jun 26, 2007
97
There should be some way to sync your contacts with your pc to outlook, then you'd be able to sync them in iTunes with the iPhone. Pretty easy in most cases.
Marianne
2,326
Massachusetts
marianneschultz.com
well, you should use software, since there is no way to get your contacts from your blackberry directly to your iPhone (unless you want to enter them by hand). your blackberry should have come with a cd with software on it. see this site (i just googled "blackberry windows xp" to find it) for step-by-step instructions. you need to sync your blackberry contacts to outlook on your pc. then you can set up your iPhone to pull your contacts from outlook when you sync it via iTunes.
