Photos from iPad to iPhone?
Angelamarg
Jan 13, 2013
These photos were downloaded from my camera onto my iPad, I want some of them on my iPhone, can I do this?
JON35Y
Oct 16, 2012
87
Yep, go to settings, photos and camera. Click share photo streams and it will sync all your photos to every I device you have. Simple as that! Make sure you switch it on both devices though
Angelamarg
Jan 13, 2013
Hi, I have done this, but it only seems to work with certain pics, maybe those that have been taken with the iPad? Not those uploaded from camera to the iPad. These are the ones I want on my iPhone.
Sent using iCafe app
JON35Y
Oct 16, 2012
87
Right ok, you need to connect your phone to iTunes and carry out the same procedure you used to get them on the iPad...
RoofMonkey
Jun 21, 2010
8,924
1,983
You can also email them to yourself & save them or use a wifi transfer type of app also.
evangary
Jan 8, 2013
9
Absolutely. I do it all the time for iPhone videos and pictures. You need the camera connection kit. Simply put the USB adapter on the iPad, take the iPhone/iPad USB dock cable and plug it into your iPhone while attaching the USB end into the camera USB adapter plugged into your iPad. Your iPad should open the Photo app. You can then select any picture / video to transfer to your iPhone/iPad. Easy as cake.
