Photos in "Photo Library" folder undeleteable?
Discussion in 'iOS Software' started by wildonrio, Jul 26, 2007.
  1. wildonrio
    wildonrio New Member
    Ok, in my Photo Albums there are two folders - "Camera Roll" which has all of the pictures I've taken with my phone, and then there's one called "Photo Library". In there right now is a HIDEOUS picture of a friend I have on facebook. I don't have a clue how it got in there, but what's worse is that there is no way to delete it! There is no trash can anywhere to click or an edit button of any kind. How do I delete this photo?
    So you can understand my pain, here is the picture that is polluting my iPhone:
  2. Tinman
    Tinman Evangelist
    Ugh, poke my eye out with a sharp stick, why dontcha!
    Are you sure you only have those two albums on your iPhone? On mine Photo Library merely shows every photo from every album on my iPhone. If there's something in there it is in one of my other albums.
    Also don't think you can delete photos from albums on the iPhone itself. I can only get photos off of my iPhone by unchecking its folder (which removes all photos in that folder from the iPhone) or by going to the folder the photo is in and either deleting it, or moving it to a folder that is not synced with my iPhone.
    Again, this is on a PC.
    Mike
  3. Avatar
    Sponsored Advertisement
  4. wildonrio
    Well if I go into Camera Roll there is a little trash can in the lower right hand corner but Photo Library has nothing. And why would that picture be in there? I've never even looked at it on my iPhone or anything.
    So you're saying I have to go into iTunes to delete that picture...
  5. Tinman
    Tinman Evangelist
    Yes, I think so.
    I would assume it's in a folder you have set to sync with iTunes. Either don't sync that folder or remove the offending pic from it. Next sync it'll be removed from you iPhone.
    I have about 3,000 photos that I have synced to my iPhone and have probably only viewed 200 of them--and even out of that 200 there were a few "surprises."
    In my case I keep a lot of my photos (on my PC) in the My Pictures folder. This is the folder I have selected in iTunes to sync to. iTunes then lists the folders within My Pictures with checkboxes to enable/disable syncing to those individual folders (the folders in My Pictures).
    Unfortunately, iTunes does not allow me to select folders below folders within My Pictures. This is wasteful in my case since I might have My Pictures\2007\June\Web and that folder has everything that My Pictures\2007\June has, only at reduced resolution. Yet on my iPhone I get them all.
    Looks like I'll need to create folders just for my iPhone, as My Pictures ain't working out. It was nice having all most of my photos with me, but the dups are just too much to deal with. (And now I use SoonR and can get to ALL photos on my PC.)
    Mike
  6. wildonrio
    Ok so the picture was probably in my My Pictures folder for some reason, ok that makes sense. Thanks again.
  7. network23
    network23 New Member
    I'm not at my Mac, so I can't check this, but I have the same problem. The photos in my undeletable Photo Library are from the first set I took with my iPhone. When I transferred them to my Mac, I told iTunes NOT to delete them after the copy...now I can't delete them at all (ever, apparently). No, it's not an album I set up to sync with iPhone either. I only set up one album to sync with (named iPhone) the iPhone. I've looked everywhere I could in iTunes and could not find a place to delete them there either.
    Very frustrating.
    Okay. I spent a couple more minutes looking at the albums and I think you are indeed correct. Just by adding up the photos in my 3 synced albums, the total number adds up to the number of photos in the Photo Library, which is, as you said, just a "view all" display of all the images (outside the current Camera Roll) synced to the iPhone. Good to know. I thought it was extra pictures I wanted to delete to save space.
  8. TPO_Hisself
    TPO_Hisself New Member
    this library folder is a real pain, anyone got any ideas on how NOT to have a folder with all the pics in it?
    All I want are my sub dirs with their associated photos. I think the darned thing is actually doubling the storage space too. keeping an actual copy of the photos in both locations.
    when I set up a Portfolio dir and sub dirs called A and B each with 100 photos, iPhoto converted 400 photos.... (Yawwwwn....)
    any ideas? surely there's someone out there that's smarter than me who's solved this by now.
  9. 722ish
    722ish Member
    I have no idea how to get rid of them either, is there anyone that can help with this?
    I have a pc, and I have a helluva time syncing the two, its odd.
  10. Tinman
    Tinman Evangelist
    You can't get rid of them, since they are only on the iPhone once. The Library album is merely a view of all albums combined--it isn't a duplicate of all photos.
    If you get into the photos directly, with an app like Tanzee iPhone Transfer Photo, you would see the photos are stored numerically as 100.jpg, 101.jpg, all the way up to the last photo (e.g., 1878.jpg).
    During the conversion process there are extra thumbnails created, but this is to speed the viewing of thumbs--it has nothing to do with the Photo Album album..
    Mike
  11. Norwest
    Norwest New Member
    For the guy with 3000 photos...
    Try Goggle Picasa to organize them into folders and then only sync the ones you want. Nice photo organizational tool.
  12. Spokendisease
    Spokendisease New Member
    Okay so I googled this very same question, but I have something happen that I guess others didn't get blessed with.
    I had an iphone 3G and added a folder of pics to it from my computer. I never had the photo library thing happen to my iphone. It was just the camera roll then the folder named "Melissa". But, then, my nephew decided he wanted to hide my iphone and then forget where he put it, after 2 days of trying to find my beloved iphone and not being able to locate it, I relunctly went out and bought another one. Well, while trying to add the pics back on, it did add the folder or album titled "Photo Library" and it was annoying to see all the same pics again. I'm wondering why my first iphone didn't do this but the second one did? I would have noticed the dumb little sunflower on the first one and it would have annoyed me then as well. Now I wish I still had the old one.
  13. Snazy30
    Snazy30 Member
    Ok. the only way to get rid of it is through Syncing on itunes... go to your photos tabs through itunes for the iphone. Sync/choose your folder. if you don't wanna any pictures at all just click sync. but don't check off any folders
  14. ramonlgarcia
    ramonlgarcia New Member
    ok, I have a new twist on this issue. I have an iphone that I have synced with different PCs. I have some pics on my phone that are no longer on my pc and I want to delete said photos but they have no trashbin. When I connect to itunes, these albums don't show up.
    Is there something I can do about this, since I don't have a full backup of my iphone (hd crash on previous PC)? I use both PCs and Macs and would be open to solutions for both.
  15. japull
    japull New Member
    I know this is an old post, but I thought I would put my 2 cents in. I just installed a free application called Roll Swap. It allows you to swap the current camera roll with a different one. You can back up your photos how ever you want to, click and drag (pc) or iphoto (mac) swap the roll with the app and delete the application. When you delete the application, all data gets deleted with it. Make sure you have a copy of the photos you want to keep before you get rid of the application.
  16. EvilRufusKay
    EvilRufusKay New Member
    Nice tip. Works for the camera roll but not for the photo library though..
  17. Locrieth
    Locrieth New Member
    I have a similar problem where I copied some photos from my pc directly to my iPhone via my computer. These photos aren't in my camera roll because I deleted all photos off my camera roll so it's empty but I still have these 10 pic in the library folder and there's no delete and it doesn't show them now when I navigate to my computer. Any ideas? Tempted to do a full factory reset and restore from backup.
  18. excgchief
    excgchief New Member
    I had the same problem. It took me awhile but I finally figured it out. As you know the photo library is created only when you have copied your photos to your pc and then re-synced your phone. The only way to remove one or all of the photos from the photo library is going to depend on if you want all the photos gone or just selected unwanted photos. Here is how to delete the photo library and one or more of selected photos only.
    If you want to just remove selected unwanted photos only.
    1. find the folder on your pc that your iphone photos were copied to. Sometimes if you did not create one, the iphone places them in the My Pictures folder. I always make up my own folder and put in on my desktop so I know exactly where it is. Easy to find.
    2. Create another folder and from the folder containing your saved photos, select the photos you want to put on your iphone and place them into the newly created folder.
    3. Attach your phone to the pc and open up iTunes and after selecting your device, select the photos tab and then place a checkmark in the Sync Photos From. In the drop down menu, select choose folder. Select browse and go to desktop where your newly created folder is and select that folder. Sync your iphone to that folder. Now you should have a photo library that will contain only the photos from that folder. All others should be gone.
    If you want to completly remove the photo library from your iphone. Follow the procedures above but create another folder named "iPhone Empty Folder". In step 2 above, you selected the folder that contained your photos, this time follow the same steps but this time select the "iPhone Empty Folder". When your phone is synced with the empty folder, the photo library will be gone because there are no photos to be sync'd with.
    WARNING: Be sure that you have copied any photos from your iphone that you wish to keep prior to following these procedures. Once you've removed the photos from your iphone, they can not be retrieved except by having them on your pc.
    I hope this helps.
  19. MayorFunk
    MayorFunk New Member
    I was able to clear my photo library by using ITunes and selecting a folder with no pictures and then syncing. This clears the photo library.
  20. Nelvis Taveras
    Nelvis Taveras New Member
    Ok.. Apparently the other people didn't understand what your problem was, so I will explain my problem (which was very similar) and the ACTUAL solution.
    > I worked at a place. This place had a computer. I discovered by playing with my boss' iPad that I could create albums on an iDevice, which I thought was pretty damn awesome. So I made some and synced them up. A few days later, ran into a few issues with boss and I quit. Managed to delete the pictures off the computer but now, how do I get them back onto a computer?!
    It's impossible.. Sort've.
    The solution is software. It is the ONLY solution I found anywhere at all so I'm posting it here because I find it completely unbelievable that someone hasn't figured out how to do this. The software is 4Media iPhone Max Platinum (the cheaper iPhone to PC transfer also works perfectly). The only problem is paying for it.
    And yeah guys, I'm sorry. It's literally the ONLY solution I could find anywhere. No they are not paying me. :)
  21. RoofMonkey
    RoofMonkey Genius
    Curious as to Who's problem you were referencing in a 3 - 4 year old thread :D
Share This Page
