Pin it
Sanjeev
Mar 17, 2012
166
I think a feature should be introduced to pin the apps or files (within apps) in the iOS 10 which you use frequently or on regular basis so that you can reach your favourite apps or files easily. For example To-do list which I use on regular basis in Microsoft OneNote. That will make the things very easy.
bballrob
Oct 11, 2009
1,928
479
Alaska
Pin them where? I just put my most frequently used apps on the first page of my device.
Ledsteplin
Oct 29, 2013
4,849
1,002
66
Florence, AL
There's Spotlight Search. It works pretty well for finding stuff.
Widgets. Launcher has some good widgets.
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
I do not agree with the OP’s post at all. As the other two members said, there are plenty of ways to position one’s most often-used applications in an easy-to-reach spot.
