Placing a call: I get "Call Forwarding Active" Message
velorapide
Jul 3, 2007
I get this message every time I place a call even if call forwarding is not activated on my phone. I just click "Dismiss" and the call continues on and everything is fine. My sister has an iPhone and gets the same message every time she places a call too.
Help! This is super annoying and I would like to have it resolved. Thanks for your help!
boylinator
24
the exact same thing happens to me. i originally thought it was happening because att didn't have call waiting activated on my account. i called last night and they activated the feature but i still get that message both when i place and receive calls. hmmmm
bradifus
Jul 6, 2007
Me too! I have also called tech support and have no answers yet? I would love to fix this issue. I'll keep you posted if you'll do the same. Any new developments on this issue?
deac
Jun 29, 2007
371
dittos here. I akased about it on here several days ago and never saw an answer. Glad you brought it up again. Its minor but getting quite annoying. Have turned Call FWD off and on several times and it makes no difference. And its another thing to ahve to hit while driving. Driving is perhaps my biggest problemo thus far -- seems to take more tabs to make a c all and more screen attention as the touch screen is so hair trigger. This "dismiss' is just another thing. not sure why but sometimes it goes away on its own.
bradifus
Jul 6, 2007
..,and all this time I thought I was the only one. Thanks guys.
You actually don't need to hit dismiss. It will go away on its own. Unless you have miss dialed and need to end a call right away.
I have also noticed while testing this out and making calls to and from my iPhone and Office number that it takes about five rings from my office phone before my iPhone started ringing. And from my iPhone about 2-3 rings before my office will ring. I have stared asking people how many times it rang before I had picked up and the usual answer is about 3-4 rings, but I only hear it ring 1-2 times before I answer. Why such a long delay? Could these problems be related?
deac
Jun 29, 2007
371
I have noticd it going away sometimes but your miss dial point is exactly my problemo particularly when driving. With the hair trigger response of the screen, I am miss tapping often when driving as I find this phone much more difficult to use while driving. Have to look at screen much more and aim carefuly to hit selection i want, and then when screw up, can't quickly hangup cause of the bothersome call forwarding has to be done away with.
Driving home from trip today I did find a little bit of a help however as I found that when you tap a contact selction in Favorites or recents and hold your finger down on it it will not activate and you can see if you've hit a wrong one. If so just slide your finger off that selection and you'll get no selection and can start over. This has helped a bunch while driving and even sitting still as I keep calling people accidentally. But with respect to the second part of your post, I'm not getting allot of complaints and it might be because of the delayed rings you discovered.
happy trails
Aug 6, 2007
i really don't like this message. i have had my iPhone since Friday and this morning (Monday) was the first time I noticed it.
Please help me get rid of it!
deac
Jun 29, 2007
371
Thanks for dredging this thread up as I stilll have no answer and its still aggravating. Have found nothing to turn it off. I have found if you ignore it goes away most of the time, but if you're in a hury to tap another choice like to enter a code, you still ahve to dismiss it first.
louques
Aug 6, 2007
It only happens to me when it goes to voicemail for a NEXTEL customer, because nextel voicemail is rerouted to another phone number where your voicemail is stored. Hope this helps
david803sc
Jun 25, 2007
I only get the message someitmes, actually it works correctly on mine, what it is telling you is that your outgoing call is being forwarded to another number, for example if your making a call and no one answers technicaly the call is forwarded to voicemail the phone detects that the call your making is being forwarded and it is letting you know.
I had another phone that did this as well notify me if my calls were being forwarded. my home phone is forwarded directly to my cell all the time, so anyone calling my home phone would see that message everytime they called me.
Now it should only show up with your outgoing call is forwarded, try some different numbers and see, call a number you know is not forwarded or ported over also, and see if the message does not appear. my guess is it some phones may be detecting a port as a call forwarded and it probably shouldn't do that.
David
deac
Jun 29, 2007
371
sorry David, but that is not the case with this problemo. As soom as I hit the number to call and the screen changes to the dialing screen, the call forwarding message pops up before it has even rung the first time......
as noted above for us having the problem, we've tried turning it on and off in the Settings to no avail and am simply living with it for now
and its on every single outgoing call
david803sc
Jun 25, 2007
The call forwarding setting on your own phone will have no effect, as these are two different things. I have tested my phone and I only get the message when the number I am calling is forwarded, why some of you are having this all the time, I have no idea, but it sesm to be a porblem only on some phones.
David
SCMedic
Jul 7, 2007
95
Dude, are you guys all really this dense?
It goes to "Call forwarding" until the call connects to a person or a voicemail box. It forwards any incoming calls, that would normally get a busy signal during this part of a normal call, to your voicemail, until your call connects with another person, and call waiting can beep in...
happy trails
Aug 6, 2007
i called 1-800-my-Apple about it and they told that i had call forward on (which i didn't) and had tampered with the settings (which i didn't). when i told them that i had simply opened the call forwarding section under settings he suggest that i reboot the phone by holding lock & home... that didn't fix it either
he also said that i get the message most likely because when i'm in a call the phone forwards to my phone number... when i asked him "isn't that like call waiting?" he said "call forwarding and call waiting are two completely different things."
could this just be a problem with the new update? or something? i don't want to talk to some idiot on the phone again
SCMedic
Jul 7, 2007
95
Dude, did you read my post?
It's NORMAL! It's only on call forwarding till the call connects! Once it does, take it away from your face and look at it, GONE! Because now nothing is forwarded because call waiting will work...
