Play music and games simultaneously?
Joyboy12
Aug 22, 2011
I like to listen to my music while I play bejeweled blitz. I have muted the game sounds and music, but the music still turns off when I return to my game. It worked for me before; meaning, I used to be able to listen to my music and play bejeweled simultaneously until one day it just won't let me so I am wondering if there is a simple setting to fix this problem.
Thank you!
styfle
Mar 31, 2008
3,381
As far as I know, you have to mute the game's music in order to listen to your own music. The iPhone won't play sounds from two different apps simultaneously.
styfle
Mar 31, 2008
3,381
Well you can't use two app simultaneously. I think the developer has to enable the feature to mute the sound, and by mute I mean completely turn off as if the app doesn't have sound at all.
salma
Aug 17, 2012
well why don't you try changing the ipad music volume while opening the game ? sometImes it works
Chewy Applications
Aug 21, 2012
Ask the developer if their app supports it. You can find developer support links at the bottom of app listings on the app store.
