Please help! How do i move my iPhone files to my hd?
mikemongoose
Jul 10, 2007
11
So my powerbook hd decided to bite the dust this morning, and all of my contacts, music, movies and photos are only on my iPhone. I need to get all this information back on my laptop, but all Apple could tell me was to check the discussion boards for 3rd party software.
geordisjd
2,442
There's got to be a way to retrieve all the info from your (dead) hard drive. There are services that specialize in data recovery ("Drivesavers" "ontrackdatarecovery"...). I bet you've lost a lot more than what could fit on your iPhone otherwise.
mikemongoose
Jul 10, 2007
11
I've already reformatted, all I need to retrieve is the music that is on my iPhone. Ive had one Apple consumer support technician say that there are 3rd party softwares out there and told me to check the discussions.apple site. The second technician said its not possible, and thats why you should buy your music from iTunes.
geordisjd
2,442
As far I know (but I don't know everything), there is no way to retrieve music from an iPhone to a Mac unless you run a simulation software (like Parallels) and run Windows (or if you installBootcamp). Then you can run Tansee iPhone Music to Computer Transfer (PC app) and get all you music back, for a small fee. It does work. You can also have a friend with a PC retrieve the music for you (with the same software)
mikemongoose
Jul 10, 2007
11
But since my iPhone is formatted for a mac, won't the PC be unable to read it?
