Please help I have problem with WiFi
mstx
Jan 10, 2008
21
When i try to choose a network i want , then its connected but its not showing the signal its still showing the edge network wat should i do and i go to wifi settings it shows its connected then it dissocnnects automatically after 3,4 seconds...so do u have any idea? or maybe its caused from apps?!..
please help
and thx ^_^
Eragon
Jan 8, 2008
3,056
50
Frederick, MD
How is your network configured - unsecured, WEP, WPA? Is the SSID of your router showing up as an available network? If your network requires a key, are you typing the same key on your iPhone?
Lastly, can you access the Wi-Fi on your network using other equipment - laptop, etc?
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Sometimes it helps to restart the phone and other times it helps to reset the router.
LMen
Jul 29, 2007
30
Atlanta
www.studiomendoza.com
Yeah, it sounds as if you are either not putting in the right password, or your password is not valid...
JoeT
Dec 18, 2007
911
Tampa, FL
If you put in the wrong password, it will not connect at all.
We need some more information to help you as was posted above. Also, how close are you to the access point?
Probably something on the router's side - I would suggest restarting it.
- John
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
$20 says you need to update your firmware on router, im guessing its linksys right? write back if u don't know how to update firmware and ill tell u
mstx
Jan 10, 2008
21
Well its k now every thing is perfect now , thx evryone :) .. I think it was from router I restarted it and works fine .. And my update firmware is 1.1.2 .. Do u know when it will release the newer firmware? And wat it including in this update..?
Thx
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Usually resetting the router solves this problem. Glad you got it sorted out. :D
Another one returns. Where've you been?
- John
