Please help.... Icons lost with summerboard!
jpx8080
Sep 8, 2007
Hello,
I used the installer.app program to install summerboard. Being an idiot I changed the settings to 8 icons. I'm missing all of the others now and have no way to connect my computer to iTunes to fix it. Is there any way I can get these back with my phone alone?
garretwp
Sep 3, 2007
125
Do you have access to the installer.app? I did the same thing and accidentally changed from 16 to 15 and lost some of the icons that I needed. Luckily I still have the installer.app on the screen and I downloaded the dock program to gain access to all of the icons and started rsbt and reset the defaults.
- Garrett
jpx8080
Sep 8, 2007
No actually the installer icon is gone as well...
garretwp
Sep 3, 2007
125
Are you running on a mac or a pc? Can you install the dock app via ibrickr or another type of software that will allow you to install apps with? This is the only option i can suggest to try and get access to your icons via the dock and to gain access to rsbt.
- Garrett
jpx8080
Sep 8, 2007
I use windows. But am away with the military and have no access to connect my phone. That's why I was hoping there was a backdoor to summerboard.
theraker007
Jun 15, 2007
322
this happened to me and I just restartwd the Pune and they came back, try holding the home and power buttons don to reset the phone
gcvt
Jun 21, 2007
1,029
San Francisco
Same thing happened to me last night. All I had to do was turn the phone off and then back on. Everything came back.
jpx8080
Sep 8, 2007
I've tried both of those. No dice. This sucks.
garretwp
Sep 3, 2007
125
He needs to some how gain access to rsbt and change restore to the backup that the the software saves. I had this same problem. The only way to do it is either have a computer handy or have access to the installer.app and install th dock.app to allow you to choose the rsbt software.
- Garrett
