please help! iTunes has NEVER recognized my iPhone!
07TouringZ
Sep 8, 2007
I had to activate the phone on my friend's macbook. i have a pc, i have upgraded to iTunes 7.4, and tried 7.3; it recognizes my ipod like always, but has yet to recognize my phone. :( I am so sad. please help!
aknightstale41
1,747
52
Long Island N.Y.
Hope this helps
You might want to try another usb port on your computer, and also open up iTunes before connecting your iPhone that might help.
Also find out if you have too many programs running on your computer at startup, that sometimes kills the connection between the iPhone and the usb port. Make sure you have enough ram , i have a gig and with windoes vista i probably need more, hope this helps
07TouringZ
Sep 8, 2007
thx i tried all of that stuff...my usb ports are all working as evidenced by connecting my ipod to each one...already on select startup in xp...tried all forms of connecting before/after iTunes started, etc...i don't know what to do!
aknightstale41
1,747
52
Long Island N.Y.
hmm, maybe on select startup you have something turned off that should be on for iTunes. My iPhone dosent always get recognized when I plug it in, I usually have to restart the computer and open iTunes and then plug it in. If its getting recognized on your friends cpmputer, then at least we know the problem is with your computer and not your iPhone. If you friend is running xp as well maybe you can run a msconfig and duplicate his startup and services protocal, good luck and hope this helps ya
headtowall
Aug 3, 2007
14
every now and then my iTunes doesn't seem to recognize my iPhone. I usually just turn the phone off and wait a minute before I turn it back on. While waiting, I close iTunes and then open it back up. Has worked every time for me. But it doesn't sound like my problem was as severe as yours.
Why not call Apple support?
07TouringZ
Sep 8, 2007
thanks everyone. I spent some time with Apple support and no change. HOWEVER, after trying again and again to re-install 7.4 and 7.3, I tried once more uninstalling and reinstalling 7.3, and it worked! Needless to say, I am sticking with 7.3 for the time being. Perhaps when I work up the courage I will switch to 7.4.0 for the ringtones. thx again
binbs
Sep 13, 2007
Where did you find an older version of iTunes?
dealers
Oct 18, 2007
iTunes
How did you do it? I have 7.3 and XP SP2, the computer only recognize "Apple Model Device" in the usb device manager. I tried many method, including, plug into different usb, restart in the my computer, service area, I have a GIG of memory and still did not work.
I turn on the iTunes first, then plug in, nothing happens!
Any advices.
truehybridx
Oct 31, 2007
40
im having a problem similar
i jailbroke and unlocked my iPhone and on iTunes 7.4.1 and when i goto sync music it ends up copying 1 song and then it says "disc could not be read from or written to"
15,385
1,023
hey guys, i had the same problem a while ago, and here's what i did to fix it:
acosmichippo said:
1) open "run" from the start menu, and run "services.msc".
2) find "Apple Mobile Device".
3) In the "status" column it will tell you if the process is started or not, and the "startup type" column will tell you if the process will start automatically when windows starts. The goal here is to set the status to "started" and the startup type to "automatic".
4)To do this right click on this process, and then click on "Properties"
5) In the "general" tab find the "startup type" drop-down arrow menu and make sure "automatic" is selected. Select it if it is not.
6) Also in the general tab check the "service status". If it does not say "started" then click the start button.
7) at the bottom of the properties window click "apply"
hope that helps someone out.
kamil234
Aug 22, 2007
54
mine did that, i reinstalled iTunes and restarted phone/ computer and it worked.
budjev
Nov 13, 2007
41
Noblesville, IN
I had similar problem. I had to go to start/run/ type in services.msc. Look for the Apple Mobile Device, click on it and start. Once you click on start under the status bar it should say "Started"
Dipwind
Jan 1, 2008
Hi Guys,
I've tried almost everything and I still got the problem, when plugged in to my computer PC WIndows XP Sp2 the iTunes "Version 7.5" do not find the iPhone and froze, I need to unplugged the iPhone and restart the iTunes to get on working, Immediately after I did the same with my Ipod and it sync and recognizes the device so I’m completely lost at the moment.
Any extra help would be appreciated.
Thanks in advance
Dipwind
15,385
1,023
have you checked the status of the service "Apple mobile device"?
have you tried uninstalling & reinstalling iTunes?
Dipwind
Jan 1, 2008
Hi acosmichippo,
Yes I've checked that I had also checked the "devmgmt.msc" and I have all correct at least as they say.
On the last hour or so I've tried again and no positive results, I don't know if I have on my firewall a setting that blocks the communication I'm not an expert and the last thing I want is start changing what I don't know.
Once again thanks in advance
Dipwind
15,385
1,023
have you tried uninstalling iTunes, and then reinstalling it? this has been known to clean up any software flukes that may arise... especially on PCs.
Dipwind
Jan 1, 2008
Yes I also did that, I downloaded the iTunes again and nothing.
I'm living in UK, so I don't know if there are anything different to do, next step I will call to Apple Support and will see.
Many thanks
Dipwind
