Please help me...I lived in Indonesia,and I got my iPhone from my aunt in U.S
nduthzzz
May 16, 2014
I can't find network service and my sim card it's not detected.(caused I'm using Indonesian provider). So I've been to reset all setting from my phone ( 3G; 16G ), after that.. my I phone stuck on connect to iTunes and slide emergency call. So, can u help me to escape from this problem?
5,580
You need to unlock it. You have a few options.
1. You can buy an IMEI unlock online, but you have to know what the original carrier and they aren't cheap like they used to be.
2. You might be able to get your carrier to unlock it.
3. You can use the ultrasn0w software unlock, depending on the baseband. You might have to install the iPad's baseband on it to get it to work.
4. You can buy a Gevey SIM card unlock.
nduthzzz
May 16, 2014
Thanks for your suggestions I'll try now
