Please help me with syncing question
Grifftech
Dec 14, 2007
46
I have created a playlist in iTunes called "Dance" and I initially populated it with songs from within iTunes, but now I have downloaded songs via my phone and added them to the playlist through the phone, but now how do I get the playlist in iTunes to sync with the changes I made.
If I sync the phone it reverts the phone back to what is listed in the iTunes version of the playlist.
Thanks,
chris
6,683
50
When your phone is connected to the PC and you have iTunes open, Click on Music at the top of the screen that displays your phone's summary. What do you have checked there?
If Entire Music Library is selected, then the playlist should be copied over no matter what. If Selected Play lists, Song etc is selected, then you need to make sure that the playlist you created is selected in the list below.
Chex
Dec 17, 2008
592
PA
After you transfer purchases you'll need to manually add the new songs to the playlist.
Sent from my iPhone 5 using iCafe app
