please help me with video problem!
daveh98
Jun 27, 2007
23
I have downloaded both videora and ialive video converters. I am converting from AVI to h.264 and the resolution is set properly. The converted files play perfectly once i transfer to the iTunes library but when i sync with my iPhone the videos are corrupted with a "green" screen on a third of the screen. Its like green flashing lines and is very annoying. Has anyone experienced this and know a fix? Please help!
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
Try converting to .mp4 instead of h.264. I have not had a problem yet using videora.
daveh98
Jun 27, 2007
23
I have converted to mp4 as well. Ive tried lowering the bitrate..everything and I cant seem to figure this out. I have seen another person complain of the same issue but thats it. No internet sources seem to have this issue.
The movies just play fine in iTunes but when synced to iTunes have green lines corrupting one side of the screen.
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
Friend, I'm at a loss. If it were me, I would try updating my graphics card drivers.
billouparis
Sep 18, 2007
same problem here, can't figure it out neither...
Problem solved!
Worked like a charm when a changed the frame rate to 30 fps
Try for instance for a 16/9 movie these settings:
568*320
1500 kbps
30 fps
Should be fine! It is on my iPhone at least!
