Please Help*
lilwaters
Dec 8, 2007
49
Houston, Tx
im having very difficulties trying to figure out how the iPhone works...
I have a unlocked iPhone which has 1.1.1 firmware.
my you tube wont work...says "cannot connect to youtube"
i want to beable to delete my icons off my summerboard so i can see my clean ass wallpaper!
is there any way to update my firmware with an unlocked iPhone? I had someone do it for me so im not sur eon how they did it but its works...
but I want to beable to use the iPhone pretty much for what it was made for...
so if anyone can walk me step by step through any of these it would greatly be appreciated..
thanks again
6,682
49
I am not sure about unlocked phones for 1.1.2, but I am sure that you can seach for it and find your answer.
As far as the YouTube problem, I am not sure what to tell you. I might be a problem because you are unlocked. There is supposed to be a fix out there in Installer - I believe.
And if you delete the icons off your summerboard, then how are you going to launch any apps/programs? I suggest finding a transparent icons theme.
Morval
Oct 23, 2007
101
Buffalo,NY
check out this thread for all sources in installer. after u do that u will have some sources that will help u with your youtube. Add All Installer Sources for maximum app selection
also download PLAIN JANE from themes. This will allow u to have semi-transparent icons so u can see your wallpaper
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
and then download "dock" this app makes all other icons disappear. Actually they hide and when you "grab" the very bottom right part of the touch screen they appear as long as your finger is on the screen. Pretty sweet app
lilwaters
Dec 8, 2007
49
Houston, Tx
nevermind its on but how the hell do i use it! how do i get all my icons to go in the corner?
Morval
Oct 23, 2007
101
Buffalo,NY
to use the dock app u must put your finger on the little sunburst in the bottom right corner of the screen. then drag your finger twards the middle of the screen. then slide your finger in a arc to the app u want to use, and then let go. keep your finger tuching iPhone at all times until u get to the app u want!
Morval
Oct 23, 2007
101
Buffalo,NY
also to hide all your icons u need to download the customize app, then in there u can choose to hide all your icons.
lilwaters
Dec 8, 2007
49
Houston, Tx
i have the customize app. but do i need to download the latest version to do it because i don't think i can because mny fone is unlocked!
lilwaters
Dec 8, 2007
49
Houston, Tx
it wotn let me install the customize app (new version) because my firmware is only 1.0.2 i believe.
Morval
Oct 23, 2007
101
Buffalo,NY
i am also on 1.0.2 and have customize version 1.17. to hide your apps u need to go to icon display order and just drag what u want under the hide area. or like i said before download the plain jane theme so u can see through the apps
