Please please help
tompeet
Feb 19, 2008
So confused please help
I have a jailbroken otb 1.1.2 iPhone and iam using a turbosim type card to unlock it.
I want to know if i can upgrade to 1.1.3 and still have an unlocked iPhone, if so how?
Your help would be really appreciated
thanks.
Bone
Feb 11, 2008
1,214
The easiest way is to rejailbreak with 1.1.3 using ziPhone. This will allow u to unlock it very easaly.
Bone
Feb 11, 2008
1,214
corect. The ziPhone jailbreak is by farr the simplest way but u will need to be in 1.1.3 to do it.
Bone
Feb 11, 2008
1,214
u will want to since your phone to your iTunes to save everything and then update to 1.1.3 then restore. After this start your jailbreak and aft about three minute u will be don and u can re since your phone to get back all of your stuff.
themanofthedark
Jan 5, 2008
2,674
25
Boston
oh yes - since ziPhone unlocks 1.1.2 OTB phones as well, you may want to throw away your turboSIM.
just select activate, jailbreak, and unlock, but before you launch the process, you will need to take out any SIM in the phone (so that iPhone has no SIM inside)
singlefilerock
Dec 27, 2007
82
also do i just update or do i restore. Just i don't want to loose all my data on the phone
restore.
make sure you back up all your contacts and such though..
it should do this automatically.
i was just as scared as you when i first did it
but its really nothing..
apps are easy to get back
and contacts all come back =]
