Please recommend Bluetooth headphones that work with iPhone
jgodden
Sep 6, 2007
21
Charleston WV
Im looking for a pair of bluetooth headphones that would work with the iPhone. Something like this: http://cgi.ebay.com/NEW-MOTOROLA-HT...yZ133229QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Im thinking since iPhone doesn't have A2DP, im going to need one of those ipod connectors that hook up to the dock connection, but i don't know if that will work.
Personally, id like a pair of headphones that would work with my iPhone, and with my laptop (via bluetooth) to listen to music/watch movies.
jgodden
Sep 6, 2007
21
Charleston WV
I went ahead and bought these: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=250209666862&ssPageName=STRK:MEWN:IT&ih=015
Im sure that setup will work with my computer, at least. And as far as I can tell, all i need now is some sort of compatible bluetooth dongle for the phone. My only question is, do i need to go with one that hooks into the headphone jack, or one that goes in the ipod connector?
Will something like this work? http://cgi.ebay.com/ebaymotors/Jabr...008QQitemZ180209670981QQrdZ1QQsspagenameZWDVW
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
I was doing some research on a good set of over the ear headphones to listen to music on the iPhone through bluetooth and all of the ones that I have seen that are compatible all have a base that connects to the bottom port of the phone (not usable with a case on the phone on any of the ones I looked at) and there is one set that I found that has a dongle that goes in the headphone jack but it is an enormous round thing the size of a hockey puck. It defeats the purpose of having a bluetooth headset if I have to have this clunker swinging back and forth off the end of my phone. I would have to set the phone down on a table and then it isn't truly portable then is it?
http://www.myblueant.com/x5_stereo_bluetooth_headset_headphones_a2dp.htm
Jun 18, 2011
Thanks for the information, I was recently disappointed to find they didn't have this item at Best Buy, instead bought the only Bluetooth headset a Rocketfish Mobile mono that was in stock at the time only to end up returning it. I did find the model you suggested on Buy.com.
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
They stay in my ear pretty well. I only use them at they gym. I don't do much running to say if they stay in or not. I'll maybe adjust them once. Also, I use the comply foam tips and not the stock tips.
Mar 31, 2012
Just ordered a pair from Amazon. Looking forward to trying them out. Thanks
Shan S.
Oct 23, 2011
29
I have been using the Motorola S9 and Motorola S9-HD for a couple of years now. The S9's are a great set of blue tooth headphones with good range .
Here is the link for the S9-hd which is a couple years old but in all reviews they have always done well, and have a really good sound quality.
http://www.amazon.com/gp/product/B0..._m=ATVPDKIKX0DER&pf_rd_r=01KKVTGMTCYCH0FR4VJD
They have have been replaced by the S10-HD. I have not tried those yet, but most reviews I have read say the S9 series is still better sounding.
http://www.amazon.com/Motorola-S10-...s-Packaging/dp/B004BHCSQC/ref=dp_ob_title_def
