please tell me the easiest / safest way to jailbreak and unlock
southmade
Jun 29, 2007
44
i did about 5 or 6 of the 1.0.2 iPhones but i haven't tried a new firmware version 1.1.1
what is the most simple fast and safe way to do everything straight out of the box
thanks!
jaydoc1
Sep 23, 2007
608
First off, sync before doing any of the following.
http://forums.everythingicafe.com/t...1-1-without-restoring-to-1-0-2-windows.12715/
The above is a very easy and reasonably fast and reliable way to jailbreak and install Installer at once.
The following is by far the easiest:
http://forums.everythingicafe.com/threads/jailbreak-1-step-no-software-download-mac-or-pc.13926/
People are having very good luck with both. When using the second method, make sure when you visit the website and your phone crashes that you don't do anything. It will do a soft reset after about thirty seconds and then you're good to go.
southmade
Jun 29, 2007
44
ok what i do not understand is how do you use safari to navigate to the webpage unless your iPhone has been jailbroken?
jaydoc1
Sep 23, 2007
608
You just type in the web address in the address bar like any other website.
jaydoc1
Sep 23, 2007
608
BTW this doesn't unlock your phone, it just jailbreaks it and puts installer and Summerboard on it.
