plzzz help
2white2fight
Mar 31, 2009
196
925 the bay
so i wana go back to 3.0 but when i hit restore i put 3.0.1 on ensted of 3.0 so now its in recovery mode with error 1005 and ive tried using red snow and it doesn't work. help?
RossMc
Jun 28, 2009
1,124
Newcastle, UK
Open up iTunes
Hold down shift on your keyboard and click restore choose the 3.0 .ipsw file from your documents ( Or wherever you have download it to) and it will downgrade back to 3.0
I have tested this and it works
If you haven't got the .ipsw file here it is
http://appldnld.apple.com.edgesuite...090617.VfgtU/iPhone1,2_3.0_7A341_Restore.ipsw
iphonewarrior
13,847
701
Restore your phone with 3.0 FW?
Why don't you like 3.0.1- there are no differences except the sms problem.
kirbaby
Jul 21, 2009
55
South Bay, CA
Are you doing this just to jailbreak? With redsnow, you can jailbreak with 3.0.1 firmware. I was acually wanting to go back to 3.0 firmware too, but it was really complicated, but I was researching, and I found I could jailbreak on my firmware! Just YouTube redsnow if you're looking to do that man.
kirbaby
Jul 21, 2009
55
South Bay, CA
And make sure you download the 3.0 file for redsnow as instructed, not the 3.0.1.
RossMc
Jun 28, 2009
1,124
Newcastle, UK
Going back to 3.0 from 3.0.1 is easy all you do is download the 3.0 ispw file open iTunes hold down shift click restore in iTunes and choose the 3.0 file then your done.
