Podcasts showing up as songs instead of podcast
iCop
Jul 7, 2007
87
Tucson, AZ.
Perhaps I am doing something wrong, but several of the podcasts I have downloaded and put on my phone don't show up in the podcasts area. They are listed in my songs though. Example: The Apple Phone Show
Am I doing something wrong or can I only store a defined amount of podcasts?
XQUIZIT
Jul 8, 2007
They should also come up in the videos section of the iPod. That's where you can watch them.
Gray
Aug 19, 2007
41
I'm having the same problem. Is there a way to fix it? They showed up fine on my iPod video. Ughh, frustrating. First real problem I've had though.
runcmd
Aug 6, 2007
46
Rabun Gap, GA
possible answer
If you're downloading the podcast separate from the iTunes store - then the association required in the ID3 tags may be missing.
Leo Laporte from episode 389 of the 'Tech Guy' podcast recently answered this question this way:
Q Matt from Tenessee - Older podcasts don’t show up as podcasts.
Change the genre of the podcasts to Podcast. You can also try going into the iTunes directory and moving the podcasts into the iTunes Podcast directory.
Apple uses the extended MP3 tags available in ID3, that has the words iTunesPODCAST in it, and then iTunes see’s that and automatically puts it in the iTunes podcast directory. Leo recommends MP3Tag
Show notes here
Podcast here
