Podcasts
jimmy-m
Jul 19, 2009
40
I am going to be somewhere for a week that will (hopefully) have cell phone access, but no kind of wifi service. I listen to a lot radio programs, which I download daily.Is there a way to download podcasts directly to the iPhone? I can take a laptop with me, but it isn't the computer that has iTunes on it.
Any suggestions?
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
You'll be able to download podcasts if the file is under 10MB. But regardless of size, you can stream the podcast and listen to it that way instead.
greenjbhsd
Jul 13, 2007
571
I use Mediafly for my podcasts. It does not need wifi (regardless of file size) and will work with the 3G network rather well. If you have wifi available you can preload them before you travel to at least get some on there.
jimmy-m
Jul 19, 2009
40
I got the app, thanks. It found 3 of 5 daily shows, 1 of 2 weekly shows.
I'm trying to figure out how to extract the shows' links from iTunes.
Anyhow, even if I can't get the others, I can stream them. When I tried it before, it completely tied up Safari.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
Stream them from the iTunes store, not from safari.
