Pogoplank
diverdown
Sep 12, 2007
971
49
NYC
Ok... I just downloaded and installed pogoplank.....very cool app. Currently i am using the default theme. i downloaded a fews for it from Cydia, however, when i enable them from PPSettings, pogoplank crashes after the respring. The default themes work fine though.....
I am running Winterboard with the illumine theme, 5 icon dock and 5 icon springboard and lockscreen info....but like I said pogoplank works fine with the default theme....
Any help or thoughts would be appreciated.
~S
connie
Jul 11, 2007
2,839
105
So Cal
That's weird I am running five icon dock with the penguin Pogoplank theme, it works fine for me. Maybe it's not liking something you have installed on Winterboard, try unchecking a few things your not using or try it without five icon and see if it makes a difference although I am running that and it works but it must clashing with something you have installed.
diverdown
Sep 12, 2007
971
49
NYC
Thanks everyone...I'll try unchecking the five icon springboard and see if that helps...
~X
diverdown
Sep 12, 2007
971
49
NYC
Ok, I turned off the 5 icon springboard and it seems hit or miss .... some themes work other don't.
~S
