Positioning of app icons on screen
KPSK
Jun 13, 2007
123
I have not had an iPhone since the 3. Is there a way that you can put the apps around the outside of screen or will they only line up in rows and cover the whole screen? Thanks
darkpoet25
Dec 20, 2008
95
30
Indianapolis
No they won't be able to. You can however group them into folders(which is what I do), or you can just arrange them across the top part of the screen, creating more pages. Which depending on the number of apps that have will fill up all the pages fairly fast. If you try and space them, they will automatically line up in a row.
