Post-Modded iPhone
CaptainZed
Aug 8, 2007
Hello all,
I want to get into modding my iPhone, but like all of the first time modders are a bit squeamish. I've read plenty on the subject and it appears that bricking the iPhone isn't very easy to do. I am curious though, after modding, does everything still work the same? Do you still sync through iTunes and only use iPhoneInterface when you are modding? Any problems with AT&T?
Thanks!
SiLeNtKiLLa
Jul 4, 2007
134
Atlanta
Hello all,
Thanks!
I can assure you, if people arent able to sync their devices, 10 times outta 10 they probably wont mod it. So you have nothing to worry about, mod away, make your device sexxier than it already is.
