Pot Hole locations
VA7DB
Nov 23, 2011
Vancouver BC Canada
I'm looking for an app that can be used to log lat and Lon positions for identifying and emailing Pot Hole locations to the local department of road repairs.......anyone have any ideas? Dave
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Get any gps app that allows you to drop pins.
Try motionx gps. I use it and you can drop pins and it will tell you coordinates.
Cabby 49115
May 10, 2011
26
London, United Kingdom.
I am in London, while I think this app would be a good idea nothing would get done by the authorities.
Sent from my iPad using iCafe app
iHolophyte
Feb 19, 2012
317
35
Manchester UK
www.youtube.com
If you're in the UK there is an app called "My Council" in which you can report pot holes along with every other issue the council serve. I use the app all the time and I find when you use the app it gets done where as if you email the problem it doesn't.
iHolophyte
